V672 universal amplifier
andow
Austria
Hey, just wanted to show you my latest build: stereo V672 - racked with lots of bells and whistles.  8)
Can be used as microphone preamp, line amp, DI-box (Bo Hansen), distribution amp (two outputs) and summing amp (with external summing resistors). And I can already tell that this will get a lot of use, these old german modules sound excellent!
[silent:arts] said:
Great looking  and realy universal, good job  8)
Thanks, really appreciate it!
You might have noticed some ideas are inspired from your designs... ;)
saint gillis said:
Great job, how did you print the panel?
Thanks! The case and front-/backpanel are from Frank from frontpanels.de. Highly recommended, btw! This is the best 19" case I ever had...
Very nice looking. I racked a pair of these a few years ago.
Because they have dual outputs, you can take a pair like this and a a mid-side output. I remember it was very cool.
Pretty nice unit...  I was building a very similar version at the same time : )
Have a look at the pic!
I am using the same Gain-Control.  Two Grayhill rotary switches for the input resistor-pairs and the feedback resistors and also brought the +/- 1,5 dB Trim-Pot to the front. I am not using an additional PAD as the Gain-Range is from 0dB up to 63dB (for sure, you Gain-Range is from -20dB upwards.
I added a bridged T-Pad Attenuator for the Output (also a Grayhill). So, you are able to drive the V672-transformers into nice saturation. Together with the "free-Mode" of the Gain-Control, you have multiple possibilities to shape the Sound.
I also brought the V672-internal Highcut (Air-band, 15kHz) to the front and added a DI-Input plus link. So, you are able to connect your Amp AND record the signal. The LED-Meter is a Neumann MO33 which they are using in their U5072 danner-format meters. The brightness of the LEDs is dimmable.
I am thinking about creating a 2-channel bridged T-Pad, so, that I can also use the second transformer-balanced output as well.
But that means a Grayhill-switch with crazy 38 Resistors on it!
It is very nice to see all these DIY and racking-projects and all the crazy people who are spending so much time on it! Very inspiring, thank you all!
Sorry,
the size of the pic was bad to handle...
Hope this is better...
