RuudNL
Opto compressor experiments
« on: October 22, 2018, 08:24:40 AM »
At the moment I am experimenting with an opto compressor.
My prototype sounds good, especially when the ratio is not very high (say 2:1 and the threshold is low).
But...the problem is that my opto compressor is slow. And this is probably why it sounds pretty good!
I used VTL5C1 and VTL5C2 vactrols, without a very big audible difference.
Now, looking at the specifications of the vactrols I use, I see reaction times of a couple of milliseconds.
But some manufacturers of opto compressors claim attack times of 0.5 mSec!
How do they do this? As far as i know the cadmium sulfide cell usually needs time to get to the new resistance value.
Who knows more about this subject?
« Last Edit: October 22, 2018, 02:27:45 PM by RuudNL »
There is a solution for every problem!
http://www.vansteenisaudio.nl
L´Andratté
Re: Opto compressor experiments
« Reply #1 on: October 22, 2018, 12:03:55 PM »
2cents:
One method is to drive the vactrol with a gate signal from a comparator (used e.g. in the Studiosound preamp limiter, probably not helpful in your circuit ), another useful thing is to add a little dc-bias to the sidechain to overcome the "led-turn-on-threshold-dead-zone" ;).
But attack speed is always an issue with vactrols...VTL5C1 is already one of the fastest
Strictly amateur since 1973...
abbey road d enfer
« Reply #2 on: October 22, 2018, 12:23:25 PM »
Now, looking at the specifications of the vactrols I use, I see reaction times of a acouple of milliseconds.
Ted Fletcher designed an opto compressor where the vactrol was under servo control; one LDR being in the FB loop of the LED driver. He claimed very small attack times, but I would think the release time was altered.
Now, if you look at the response time graphs of vactrols, you can see they are faster in the first millisecond than later, so by carefully balancing the resistor values, you can find an operating point where speed is increased.
For example, the VTL5C1 decreases from its obscurity value to about 2 kohms in 0.5ms. That is enough to produce about 20dB Gain Reduction (assuming it works against a 20k resistor). Indeed it takes some serious LED driver to supply 40mA.
When you complain about your comp being slow, is it the attack or release time that's slow?
RuudNL
« Reply #3 on: October 22, 2018, 12:59:56 PM »
Well, I am not complaining (it sounds pretty good), but the attack time could be faster.
Especially when I monitor the signal on a PPM meter (integration time 10 mS.), I can see serious overshoots.
12afael
« Reply #4 on: October 22, 2018, 02:18:07 PM »
Ted Fletcher also use a bridge configuration to allow more compression. probably nothing to do with attack but interesting.
heavy metal is the law!!!
RuudNL
« Reply #5 on: October 22, 2018, 02:28:29 PM »
Interesting idea!
abbey road d enfer
« Reply #6 on: October 22, 2018, 02:34:51 PM »
If your goal is a compressor that is capable of dealing with fast transients, opto is not the best choice.
In fact, dealing with <10ms transients is not easy, whatever the technique employed (except digital). The best results are achieved using compound techniques, such as cascaded compressors, compressor with delay in the audio path and combination clipper/limiter.
« Reply #7 on: October 22, 2018, 03:42:49 PM »
How are you changing ratio?
RuudNL
« Reply #8 on: October 23, 2018, 08:44:47 AM »
I use (DC) feedback from the LED in the optocoupler to the LED driver circuit. So: changing the gain in the LED driver stage.
At the moment I am getting pretty close. I increased the value of the resistor in series with the cadmium sulfide cell  (in the attenuator) , so that less change in resistance from the CDS cell is needed for the same amount of gain reduction. This improved things a lot, the attack time is now pretty fast. In fact I think it is good enough for what I want to use it for. Even the clicking sound of two screwdrivers hitting each other is efectively compressed! (And that is a very short peak!)
« Last Edit: October 23, 2018, 08:56:33 AM by RuudNL »
abbey road d enfer
« Reply #9 on: October 23, 2018, 10:24:56 AM »
That is good news. How is your PPM reacting to that? Does it still show overshoot?
RuudNL
« Reply #10 on: October 23, 2018, 12:14:40 PM »
On a standard DIN PPM (10 mS integration time) I don't see any overshoots now.
I will do some real measurements to get an idea of the attack/release times.
john12ax7
« Reply #11 on: October 24, 2018, 05:24:59 AM »
Where did you get the vactrols? Thought they were no longer for sale due to rohs requirements.
« Reply #12 on: October 24, 2018, 06:41:24 AM »
For example:
https://www.thonk.co.uk/shop/vactrols-vtl5c/
scott2000
« Reply #13 on: October 24, 2018, 06:49:46 AM »
https://www.ebay.com/itm/Xvive-Audio-VTL5C1-Opto-Coupler/331860686515?hash=item4d447036b3:g:l7wAAOSw2GlXKNOR:sc:USPSFirstClass!32828!US!-1
Many of the series are there too.....
I've bought chips from here and they are legit.....
« Last Edit: October 24, 2018, 06:55:50 AM by scott2000 »
RuudNL
« Reply #14 on: October 25, 2018, 03:18:01 PM »
Today I measured the attack time of my opto compressor prototype.
Attack time is in the range of 1 or 2 mSec. Fast enough for me! (Measured at 6 dB gain reduction.)
rogs
« Reply #15 on: October 28, 2018, 04:06:34 PM »
One of the Silonex optos - the NSL-32R3 - has similar attack and release times to the Vactrol, and being a current device can be easier (and cheaper!) to find..
http://www.farnell.com/datasheets/1674205.pdf?_ga=2.146972542.899153935.1540673651-1951666110.1540673651
abbey road d enfer
« Reply #16 on: October 28, 2018, 04:56:04 PM »
Are you positive? My understanding is that Silonex has been absorbed several years ago, and now the only Vactrols available are those of Perkin Elmer Electronics.
« Reply #17 on: October 28, 2018, 05:38:22 PM »
Farnell seem to have a few thousand in stock:
https://uk.farnell.com/w/c/optoelectronics-displays/optocouplers/photocell-ldr-output-optocouplers?range=inc-in-stock
abbey road d enfer
« Reply #18 on: October 29, 2018, 04:05:40 AM »
OK, under the Advanced Photonics brand. So much confusion with successive takeovers...
ppa
Re: Opto compressor experiments New
« Reply #19 on: December 27, 2018, 07:16:54 PM »
I used the NSL-32R3 on an optocompressor that I designed  for very good attack and release but Vactrol was better for it for its sound look even if with slower response times. In any case with Vactrol my optocompressor was  fast enough so I left it as reduction element.
I used the vactrol on the first sector of its resistance characteristic for fastest response.
EDIT: is very probable that several fast optocompressors uses this subterfuge for getting faster attack and release.
« Last Edit: December 27, 2018, 07:40:28 PM by ppa »
Last post February 05, 2007, 09:25:50 AM
by gary o
Last post February 23, 2008, 12:35:24 AM
by Bluzzi
Last post July 10, 2010, 01:31:09 AM
by JTraverse
Last post August 22, 2017, 10:27:09 PM
by EmRR
