Winetree
Re: Banzai's KM84 DIY Body & PCB kit build thread
« Reply #100 on: July 21, 2019, 04:22:32 PM »
Bram,
 I've got 4 mics sitting with just the transformer wiring to  connect.  After pulling one wire out of a transfo, I gave up.
 Could  you post the definitive wiring for the Haufe transformers.
kante1603
« Reply #101 on: July 22, 2019, 06:35:37 AM »
Hello,
did my 3 kits finally, biasing went well.
Thank you both Mike and Graeme for these wonderfull kits,it was a pleasure building them.
I can confirm that the supplied set screws should be exchanged to better ones.
For the transformer I had the 3U types,with a bit of „dremeling“ they went in well in the end.
Two drops of hot glue hold them in place nicely.
I did a quick testing today,and I was very happy with what I heard.A silky top end,just like the originals,never harsh.
Attached pic of proof during test setup.
Best regards,
Udo.
(Edited typo).
« Last Edit: August 14, 2019, 01:03:17 AM by kante1603 »
BramK
« Reply #102 on: July 23, 2019, 08:14:33 PM »
Bram,
Hi Winetree, apologies for not responding sooner, I wasn't getting thread updates.
1. On the Haufe transformers, on the side that has only 2 white wires,  solder these together.
2. On the opposite side, solder together the yellow and green wires.
3. Then follow the color conversion guide below to connect to the PCB:
HAUFE --> CINEMAG (PCB Designation)
Black   ---->   Red (R)
Red      ----->    Green (G)
Blue   ------>  Blue (B)
White ---->  Yellow (Y)
To make things less confusing, I extended the Haufe leads with the cinemag color wiring.
And here are the finished mics after painting (and Neumann badges... just for funsies  ;D)
Thank you Banzai and Graeme, I've only had a few moments to test these out on acoustic and voice, but I'm loving what I'm hearing so far - they sound clear and smooth and the noise floor is impressively low. Not experiencing any RFI/EMF interference that a few others had mentioned.
« Last Edit: July 23, 2019, 08:19:37 PM by BramK »
kante1603
« Reply #103 on: July 23, 2019, 10:00:30 PM »
Congrats to your builds.
May I ask how you removed the mesh out of the brass tubes for painting?
It looks like they are glued in?
Thank you in advance,
best regards,
Udo.
Winetree
« Reply #104 on: July 24, 2019, 12:03:32 AM »
Bran,  Thanks so much for the info and pix,
               Looking forward to hearing these,
                Your mics look great,
Robert
BramK
« Reply #105 on: July 24, 2019, 12:41:38 PM »
best regards,
Udo.
I soaked them in acetone for a few minutes.
Winetree
« Reply #106 on: July 24, 2019, 02:38:07 PM »
On the first group buy, the screen was a separate, cut rectangle you placed in the mic.
Did they glue them in on the second batch?
kante1603
« Reply #107 on: July 25, 2019, 12:44:45 AM »
Hello Winetree,
yes,looks like glue put on 4 spots inside.
Best regards,
Udo.
Fuzz Face
« Reply #108 on: July 25, 2019, 09:51:56 AM »
Black   ---->   Red (R)
Those look amazing! I gotta powdercoat mine now  ;D
« Reply #109 on: July 25, 2019, 12:00:53 PM »
Be sure to leave enough extra grey wire to reverse the leads if the mic's polarity is reversed.
I finished my mic by cleaning the brass well and spraying it with a couple of coats of lacquer.  I think that's the easiest way.
I just finished one of mine using the AMI transformer. My wiring looks similar to this, but left to right goes: blue, grey, blue, grey.  The transformers came in bubble wrap with no data sheet. My DMM showed a higher resistance when measuring blue to blue than grey to grey, so I connected the transformer as shown here. I did a quick comparison with an AKG 451b and the mic sounds great already (have not biased the FET yet), but the polarity is reversed compared the AKG. Is this just a matter of swapping the grey transformer wires around?
C
TillM
« Reply #110 on: July 25, 2019, 12:33:32 PM »
Yes. Swap them, then it’s reversed.
« Reply #111 on: July 25, 2019, 12:46:08 PM »
Perfect, thanks TillM!
« Reply #112 on: July 25, 2019, 01:43:48 PM »
One question regarding the biasing procedure. I'm planning to bias them by ear, using the stock signal generator that comes with Pro Tools. I'd be coming out of a TRS patch bay.  What I'm trying to figure out is how to "inject" the 1k sine wave into the capsule pin.
Can I just use a cable that is TRS on one end (coming out of the patchbay), and raw cable on the other end in this configuration:  positive to capsule pin, negative and shield to pin 1 on the mic XLR?
Once that's connected, apply +48v to the mic and adjust trimpot for least amount of audible distortion?
Ok, that's two questions.  ;)
C
« Reply #113 on: July 25, 2019, 03:10:02 PM »
C
Seems like that should work, except I'd add a 1uf capacitor between the capsule pin and the signal source - don't want to apply polarization voltage to your interface outputs!
Getting a line level signal up to 1Vpp may be a stretch depending on your interface as well; in the past I used the amplified headphone output of an interface for this, which seemed to work nicely, but could possibly have drawbacks beyond my understanding.
I'm having a quandary on biasing myself - biasing this mic by ear vs. asymmetry of the clipped input wave. Optimal trimmer resistance for either biasing method varies by ~800ohm - should I be giving preference to one, splitting the difference, etc.? For quiet instruments - acoustic guitars, etc., the recorded results are equal to my ears; but I'd like to use these as drum overheads where bias method may have more of an impact.
any strong preference?
« Reply #114 on: July 26, 2019, 02:17:33 PM »
Ok, great. I've got a 1000pf film capacitor to use for biasing based on Ruud's suggestion on page 2 of this thread. Do you think that would suffice, or am I better off with a 1uf cap?
C
Fuzz Face
« Reply #115 on: July 27, 2019, 09:20:21 AM »
C
1000pf works fine
« Reply #116 on: July 27, 2019, 10:07:20 AM »
BladeSG
« Reply #117 on: July 27, 2019, 10:37:50 AM »
I just finished building the first out of 2 and all I'm getting is loud hum. I used the AMI T8 and was a little unsure of the wiring but I don't think this is the problem.
Is it safe to connect to XLR to supply 48V phantom to check voltages per schematic with the capsule and body removed?
Thanks in advance.
« Reply #118 on: July 27, 2019, 12:53:33 PM »
Loud low frequency hum is always a ground or shielding problem.
Make sure pin 1 is connected to the PCB ground and mic body. Check for continuity between the body sleeve and XLR pin. Should be around 1ohm.
BladeSG
« Reply #119 on: July 27, 2019, 11:08:01 PM »
Thanks Banzai.
Thats exactly what the problem was. I remember thinking about the grounding when I assembled it yesterday!!!
Working fine and sounds great (still needs biasing), thank you again!
Steve
Last post August 31, 2018, 12:09:39 PM
by buckethead
Last post September 16, 2018, 04:20:49 PM
by TillM
Last post August 06, 2019, 03:00:51 PM
by Fuzz Face
Last post October 18, 2019, 07:12:04 PM
by midwayfair
