S-O
Re: Banzai's KM84 DIY Body & PCB kit build thread
« Reply #160 on: October 29, 2020, 12:57:24 PM »
I am also itchin to pick up a pair of these kits
fsalter
« Reply #161 on: November 03, 2020, 09:50:58 AM »
As an experiment, i built Banzai's circuit into a cheap BM-300 body with a JLI TSB-2550 capsule. I always really liked this capsule and i'm quite impressed with the sound with that circuit. Although it does'nt have that KM-84 "sweetness", it is nonetheless very impressive. The output is quite low though. Should i use a JFET with a higher Idss, or rebias? (i adjusted it to 10V, like my other 84 builds, which have a higher output)
RuudNL
« Reply #162 on: November 03, 2020, 11:00:02 AM »
If you are using an electret capsule, you can omit the components for the polarisation voltage.
There is a solution for every problem!
http://www.vansteenisaudio.nl
« Reply #163 on: November 17, 2020, 12:54:50 PM »
* Graeme's circuit  :)
RuudNL
« Reply #164 on: November 17, 2020, 01:20:27 PM »
Neumann's circuit  :P
Last post August 31, 2018, 12:09:39 PM
by buckethead
Last post September 16, 2018, 04:20:49 PM
by TillM
Last post August 06, 2019, 03:00:51 PM
by Fuzz Face
Last post October 18, 2019, 07:12:04 PM
by midwayfair
