mikeyB
I'm planning on building a transistor matching test jig based around the GM328 tester, many of them on ebay.
Quick question is: is there an equation or correction factor regarding transistor hfe at different temperatures?
The temperature is the only variable as everything else is set by the tester. Obviously, I need a thermometer and need to note this along with the test measurements.
Thanks in advance
Thanks in advance
