Check this patch wiring
JAY X
Hi!
I want to make sure the wiring of the patchbay schematic is correct.
It shows daw outputs 1-2 normalled to the summing inputs 1-2. Ok so far, but if i want to place a processor between the daw outputs and summing inputs i have to break the normalling connections... I think it is right, but i am not sure...
Thanks for your comments!
Jay x
It's ok. You can place also comp inputs below outputs and use isolated setting in the patchbay. That way you will save two columns.
Hi Moamps!
Ok!. And the isolating setting is a great solution!
Thanks a lot! :)
Jay x
