Thats interesting Ian - may I ask what is LDO (I know now .. Low Drop Out regulator chips
So the regulated dc heater is doing a fair amount of current at 12V and was contributing to hum ... and the system was quieter with a switching psu.
I guess it has to do with 'dirty current' return from the heater circuit getting into the audio ground ?
Or a case of the large current spikes spattering em fields which are being induced into wires/signal traffos ?
This is my first external psu and it can provide about 5A of dc filtered heater at +6.5V from both psu modules ... no sign of anything so far hum wise from this source.
But I've only just started 'chaining' signal racks off of it.
I *did* notice a big difference with either 'ground referencing' the dc heater negative at the signal unit or at the psu unit or just floating.
I was trying to determine if heater current would contaminate audio ground and if floating heater was useful.
I found the best by far was 'ground reference' the heater at the psu unit. Not much different was doing it in the signal unit.
Really bad was 'floating' - again not sure why! It was a significant broad hash of noise across the hum region.
It could be that there is no 'return path' for the heater current ... ? Maybe it leaks into the cathodes to ground or something like that because there is nowhere for it to get 'to ground'. I don't know.
The tube was amplifying fine just a frightfull wideband hum.
One day, I also have to measure and compare : ac heaters floating, ac heaters with centre-tap grounded, ac heaters with one leg grounded (as is common in amps), dc filtered floating, ground referenced and/or regulated
For now, I will be keeping on eye out with REW as I load up the psu with more (and more) tube stuff, then to also ding the 24V winding at 1A of JLH goodness
Modular PSU #2 is my current attempt at a higher powered psu and has a much more serious set of psu traffos. It is intended to power some tube monitor amps on one side, and a mastering chain with major tube limiters on the other side.
A 2RU with modules on the inside, toroid inside and big Edcor and filter caps on top. Again with 2 cables but this one having individual power and standby switches for each connected cable and it's associated psu traffo.
One psu traffo, the large Edcor, will be providing some 6A of heater for the amp rack, of dc filtered with seperate windings for the finals and the preamp stages.
The other psu transformer is a 100VA 2x 12V toroid for heater on two windings for seperate heaters amongst the mastering chain units.
I expect this PSU unit to be doing 11A of heater all up. The HV will be a combo of unregulated for the finals' some 250mA worth, and regulated for screens and preamp/gr amp sections able to do 150mA ....
A serious psu but quite straight forward and hopefully .. robust. So I'll be REW-watching as I go.
And a final bit of kit .. invaluable when racking these kinds of powerful amounts of heavy metal ..... one (or more) standard rack 'tray' s made from heavy duty steel plate .... 4RU, open at the front, tapering to a 40mm high rim at the back which is quite deep, like 400mm or so with a floor of same ... that nice old yellow coating on steel ... 2.2mm or so thick.
They used to be cheap in the old days. Great EM shielding and does indeed make a diff to the noise bottom line in the right circumstance.
You stick that above the psu #2 with plenty of space underneath it, on the underside of a shelf, then on top you start with the amp module, leaving plenty of space above it too .. and so on.
At this point, with PSU #1 looking really good, I'm not sure if I can do any better - I suppose, some more improvement could be had but I can't imagine it more than a dB or two.
Theoretically, the hum could go down about 12dB more, till it is buried in the noise floor; which is -130dBFS in my measurement system.
- better HV regulation module ? I get 1mVpp of hash with no sign of modulation at all on my $20 eby hv reg module.
It already uses a high speed error amp in transistors around a good quality power mosfet. The rectifiers are 4x hexfred diodes which have no 'snubbing' capacitors across each. That would be my next thing to try.
- IEC filtered mains inlet connector ? The next model I have a really heavy duty one of them, japan manu
- regulation of heaters ? possibly, but I've never been a fan especially at any significant current. But is is possible to get beefy linear reg modules and also switched mode psu modules. It is an area I'd like to try some more.
- seperation of modules ? Already done
- better layout of signal modules ? Surely a plus
In general terms, with no 50Hz ac anywhere near the signal unit, its more about high amplitude audio buzzing from one part of a circuit to another .. from the output end into the front end and/or left-right channel seperation etc. Not much impact on hum at 'silence' really.
That and of course, grounding ... always the grounding and the shielding. Return currents and seperation of etc. Shields and seperation from audio grounds, except of course, when they is not.
- better interconnect cable ? Possibly an even heavier ground line would help. I'm already using an interconnect with wires that are heavy gauge.
- better performing tubes ? No doubt! Some tubes are better than other tubes.
There could well be a couple of dB still of better signal-hum margin for a specified THD to be had from 'tube selection'. Rolling tubes is, after all, the 'last refuge of the simple'
That would be me, for sure.
I have a set of around 20 candidates to have a look at in this signal module ... av7 and at7 types .. so far, it's a close spread, within a dB or so.
My next signal unit is the fun one .. point-point wiring, with some octals as well as the smaller 9pin types ... so I can go to town and chisel on down, past the 100dB margin of the old low THD tube hum .. and into the great beyond.
There, I'll need cooling; like liquid nitrogen, to keep out the cosmic rays .. that might impinge on my grids.
I haven't even looked at other forms of noise apart from 'hum' to date - there's also a world of 'switching transients' type of noise related to rectifiers, as well as 'hiss' type noise and a good many other things so far not even on my personal radar!
Anyway, even if 'that's it' regarding hum performance, with this psu #1, I'm happy to have REW'd (subdued) the tube beast even to this level!
Next up ... JLH mini-modules all round
Here's a snap of my 'opamp test rig' silence noisefloor .... basically a variable straight-wire gain with balancing/debalancing using some of the quietest chips around ... LM49860 for debalance, another for gain and a DRV134 balancer, with an Alps potentiometer set for unity gain at the non-inverting opamp.
All that x2 for stereo. And with a groovy machined alu 'shield' for the gain opamp!
It's about
2.5dB 22.5dB better at hum than the tube getup I showed above. ** correction : 20dB measuring error!
[I confused the real-world figures with a 'scaled' figure ... sorry! . Explained later in thread. ]
That opamp cct 100Hz spike is still about 10dB higher than the ground hash of -130dBFS .... the test rig is powered by a 'JLM 3way' regulated linear psu at +/-16V.
The 25VA toroid that powers it is 'co-located' in same 1RU but this isn't much of an issue for builds without signal transformers, and using low voltage rails and lowZ chip circuits.
I have some 'toroid shielding strips' that I use here and there ... in this case they make a tiny difference, some 1dB or so I recall .. once the toroid has been 'rotated' and so on for min hum.
TheyJLM 3way modules work well, but simple lm317/337 regs are not the quietest thing available, in terms of ripple and so on. And they're best suited for the lower current requirements even at these low voltages.
I since have acquired some psu modules, similar in size to the jlm that I've generally used up to now - these are cheaper and have discrete voltage regulation circuits - they claim to be very quiet, so I'll be checking that too.
For Class A circuits especially, a really low noise supply is much better - in small current apps, little discrete 'Class A regulator' circuits should do really well.
For the bigger jobs, they can scale up or one can go to LT1083, LT1084 based linear regulators which I believe have a tighter performance spec as well as much increased power ratings.
I have one module that does +24V at 5A easily with large heatsinking - for those intermediate level JLH and Neve styled requirements
I did some REW tests of my dual channel gyraf pultec eq .... bye-bye to the tube psu and make up gain module!
So much ripple, hum and hash from the co-located psu ... ... when boosting the bass freqs
I tested the unit after the removal of the psu + make up amp modules ... using this opamp test rig .... the filter results were really good and the eq sounded totally clean and quiet with the opamps doing the make up and line amp duties.
I'm keeping the 600/600 input traffos and adding some more at the output end.
It was a blow tho' - those Lundahls in those modules cost a lot and aren't much use without a pcb
Give me an old school traffo any day - you can recycle, and recycle and on and on no probs.
Just finishing up some 'ssl mic pre' pcb modules now to do that peq makeup+line job and finally realise the full potential of the thing, after 10 years!
