Federal AM-864 adding LED's for lights
« on: November 09, 2018, 09:07:45 PM »
I'm trying to add LEDs for the power light and meter lights and thought about making this little rectifier circuit to supply the DC for this.
I'm sure this would work, however concerned about introducing noise or hum or something into the circuit. Any advice?
The added circuit is boxed in red with red circles where I plan to tap into the AC.
PRR
Re: Federal AM-864 adding LED's for lights
« Reply #1 on: November 09, 2018, 09:31:43 PM »
NO!!
The rectifier heater is at 300 Volts DC!
Minor issue: Parallel LEDs may not share well. Either use separate resistor for each LED, or put them in series.
This really uses a grounded 6.3V heater supply?
Then a simple hack off the *grounded* 6VAC winding gives a reasonable and safe 16V DC supply.
« Last Edit: November 09, 2018, 09:47:00 PM by PRR »
« Reply #2 on: November 09, 2018, 09:56:07 PM »
AHHHH!!! Thanks!
No noise issues with messing with the audio tube heaters?
Last post April 08, 2006, 07:18:56 AM
by gary o
Federal AM-864
Started by drpat « 1 2 3 » The Lab
Last post July 25, 2009, 12:47:20 AM
by drpat
Last post June 29, 2010, 05:22:14 PM
by fazer
Last post April 10, 2011, 10:18:55 AM
by schmidlin
