Hey all,
Thank you very much for these insights.
I'm thinking it also contains a diode clipper, with pots to adjust the series and shunt resistances. Also probably series diodes to simulate crossover distortion, wih pots to blend it in or out.
I wondered about the diode clipper but, though I’ve never heard one, people seem pretty critcal of the resulting sonics, a la Black Ice. Is there a method or component choice which is decidedly more pro/useful sounding? Maybe I’ll try it out and see what I hear.
I think the Zulu is basically a small cored transformer designed to saturate at modestly high levels. I am sure CJ could come up with one.
Small core like a Beyer peanut, for example? I have some of those that I could play with. Thing is, and forgive me if you’re well aware, you can turn knobs on the box and it takes the signal from a little harmonically saturated to full on warm distortion. I’m wondering how one can alter the headroom or distortion characteristics of a transformer (small core or otherwise) with a circuit... Or are you all suggesting that the only elements of this which noticeable add distortion are diode clippers?
If you add a DC supply, you could use that to DC bias the core by passing DC through a winding and provide even order distortion. I suppose you could do that with a core with a hole drilled in it and a movable slug that passes a permanent magnet into or out of the core to bias it without using DC, but it'd be somewhat complicated to machine that (at least for me).
The difference is that a small core will provide symmetric distortion, while DC bias will provide asymmetric distortion, which should sound different.
I’m doing my best to stay away from active circuits. Full disclosure, because I am still learning and haven’t done much with active/power supplied units. If there’s a simple answer to a DC supply that you’d recommend which wouldn’t change my whole layout due to safety concerns, etc.?
I think you are right. ISTR the thing is potted.
Fun stuff. So does this literally mean it could not be fixed by the manufacturer? I’m not 100% on the effects of potted, but I remember you saying something about not being able to replace caps in a Fat Box DI.
Thanks so much all and I look forward to hearing your further insights.
Mark
