Matt C said:
There's been a lot of talk here about this idea of treating ground/common differentially in a summing bus to reduce noise, and I understand the idea vaguely, but I'm having trouble picturing exactly how this would be implemented/retrofitted into a mixer. Can anyone point me to a detailed explanation of this, beyond all the little snippets I've dug up here on the board?
Just to be clear it doesn't really reduce noise. What it does do is reject ground potential differences between channels and master section.
This is what I'm imagining, someone tell me if I'm way off base here:
- Create a new 0V/common bus independent from existing grounds.
ASSuming you are talking about a virtual earth summing structure. You can call it anything you want but it needs to be a parallel bus, similar to the audio + but instead of signals, summing together the local channel audio grounds, or audio - get summed too.
The outputs of these two buses get combined differentially, effectively compensating for of all the sundry local ground potential differences.
- Connect this bus to each channel's ground (I'm guessing it should be connected as close as possible to where the + signal output is?) through a small resistor (I've read recommendations anywhere between 10r and 1k)
It needs to be sending from the local channel ground, typically near the fader/pan/etc.
- At the summing amp, disconnect the op amp's + terminal from the existing ground, and instead connect it to this newly created ground bus
There are different ways to accomplish this... Cheap and dirty is to just sum together low impedance resistors from each channel local audio ground and connect to the + sum bus amp input ( the cheap and dirty approach often uses low z resistors for the ground bus, but they still need to be precision matched for differential accuracy.) In fact there needs to be one more same value resistor from the sum to master section local ground.
The less cheap and dirty approach is a same value bus and sum amp in parallel (followed by a differential combining amp).
I have used both ways. One perhaps not obvious downside is that the number of audio sends going to the audio bus need to be the same as number of local ground resistors being bused. If only a fraction of channels are assigned to the sum bus, the associated grounds need to be deselected too, for differential accuracy.
[edit- I have cheated on the requirement to deselect grounds in some modest mixers (say 16 inputs or less). Hard wiring all grounds and living with the very small errors when small numbers of channels selected. When only a few channels are selected the noise gain of the sum amp is proportionately lower (for less error sensitivity). You could alternately back ground signal bus resistors when deselected, but that forces the bus amp to work at worst case noise gain for less than worst case situations. [/edit]
