5v333
In a common cathode tube stage with a bypassed cathode resistor, we choose the value of the cap after the resistor. 1/(2πRf)
however, doesnt the cap sees booth the resistor to ground and the impedance of the cathode, so shouldnt we use the parallel resistance of the cathode resistor and the cathode impedance (1/gm)
if we have a 330R cathode resistor and a tube that has an gm of 3mA/V at its workingpoint
1/0.003 = 333R
then the paralell resistance would be about half the cathode resistor. so we should choose a cap that is double the size that we had in mind from the start.
1/0.003 = 333R
