diydidi
Active member
I have built the attached circuit into an existing 5 channel mixer project.
It monitors by way of 2 led’s the signal level present at the output of the mixer.
It monitors L&R outputs with two adding diodes at its input.
My question is. I would like to double its sensitivity instead of the first Led turning on at 2V, i would like to have it switch on at 1V of input, and the red led at 2,5V of input.
Which components should be changed? I was thinking change all diodes to Schottky perhaps?
Thanks in advance.
Thanks in advance.
