DISA Vari-mu, add variable release/attack
« on: November 21, 2018, 09:07:55 AM »
Can anyone point me in the right direction for adding variable release and attack for this limiter. I have a hunch C1 and R4 has something to do with it.
larger value capacitor = slower release ?
thanks
Emil
scott2000
Re: DISA Vari-mu, add variable release/attack
« Reply #1 on: November 21, 2018, 09:39:11 AM »
Kingston's M670 has a nice example???
https://groupdiy.com/index.php?topic=51478.0
« Reply #2 on: November 21, 2018, 09:43:53 AM »
C1/R4 is release.  Attack is fixed at 'fastest possible', as dictated by other circuit constraints.  Insert series resistance before C1/R4 to slow it.
These things are highly interactive, if you do it as simple adjustable resistances, changing one affects the other.  Some units change the C and the R to keep adjustments more separate.
« Reply #3 on: November 21, 2018, 09:58:58 AM »
Thanks guys.
Ok so C1/R4 are release. You know what, I'll leve it as it is. don't fix it if it aint broken right.
« Reply #4 on: November 21, 2018, 11:48:27 AM »
I should say they are ’primarily’ release, there is still the charge time of the cap which is part of the attack.  At any rate it’s meant to be as fast as possible.
« Reply #5 on: February 02, 2019, 06:45:13 AM »
Ok I am going to investigate this further. After having used it for a couple of weeks i feel i would want the option of altering the envelope. Especially the attack.
Any help is greatly appreciated. Preferably i would like to have two potentiometers for attack and release with a switch to flip between the pots and original time constants.
Help!
« Reply #6 on: February 02, 2019, 06:57:50 AM »
How about adding a series pot before C1/R4 for a variable release, as you said, and add a switch witch a couple alternative values for C1. Say 1u5, 2u2 and 4u7? A pot for the attack would be better but i don't know how that would be done.
Help!
« Reply #7 on: February 02, 2019, 02:09:40 PM »
Could this work?
« Reply #8 on: February 02, 2019, 02:35:53 PM »
That's the basic idea.
« Reply #9 on: February 02, 2019, 08:31:12 PM »
Ok cool. thanks I'll start experimenting.
« Reply #10 on: February 03, 2019, 03:19:36 PM »
I just installed it and it works PERFECT! Thanks for your help!
« Reply #11 on: February 03, 2019, 08:10:39 PM »
Pic
Last post November 12, 2004, 08:04:41 AM
by StephenGiles
Last post February 07, 2005, 10:02:35 AM
by mikem
Last post July 11, 2005, 01:43:26 AM
by gyraf
Last post December 25, 2008, 07:01:14 PM
by Larrchild
