neve 1073 + 660 combo
ilfungo
ITALY
Hi I'm working on a 1073 pre/EQ + 660 Channelstrip.
I'm at the end of project I need just to rack inside the 660.
Only one problem regarding 1073:
When the eq go IN, the level increase of 3db...
It's normal?
The last question:
I want to have a true bypass of the single unit:
how can I configura the ralay to have:
a - 1073 only
b - 660 only
c -1073 + 660
THANKS!!!
It's normal?
Solved I've used 10k trim fader instead of 5k....
The last question:
how can I configure the ralays to have:
a - 1073 only
b - 660 only
c -1073 + 660
THANKS!!!
The unit is near to ready, and sound fantasctic!!!
Just 2 questions:
I don't know why when the input pot of 660 is full I've a great frequency responce,
but, when it ic from half way to down there is a roll off on low frequency... Screen shot attached
Suggestions?
Neve out
from the manual I've replaced the 5.1k resistor between  k and B- with a 5k pot ( for trim out)
but when I go down with trim there is a different level between eq in and eq out ( eq totally flat)
Suggestions?
Help please.... ;D ;D
And this is the Frankenstein with temporary knobs...
