benb
Re: bill whitlock
« Reply #20 on: December 11, 2018, 02:10:33 PM »
By the way, last I spoke with Bill, a couple years ago, if I’m recalling correctly (and I very well may not be), he said he’s not sure how necessary the hoopla and trouble is to have 120 balanced on the secondary; sounded like he needed to do more testing there.
I think the biggest thing that makes it necessary is modern switching power supplies (the word 'switching' is redundant here) that have a filter block (needed to reduce RF emissions) at the power input, with three line-rated capacitors between the hot, neutral, AND ground connections.  The one between hot and ground puts a 60Hz current through the ground wire at a level that's a lot higher than it would be just from stray capacitance. Balanced 120V puts half the voltage from the (formerly) "hot" on that capacitor, and half the voltage with the opposite polarity on the (formerly) "neutral" capacitor between neutral and ground,  thus the currents (mostly) cancel out (depending on how close in value the two capacitors are).
Of course, older/classic  guitar amplifiers are different, and the "ground reverse" switch on them won't make much if any difference in hum on a balanced power line, as either way its ground/chassis is capacitively coupled to about 60V. Ironically, these "need" unbalanced power.
On the other hand, for best safety, their power connections should be rewired to modern standards.  Is this usually done with older guitar amplifiers?
JohnRoberts
Re: bill whitlock
« Reply #21 on: December 11, 2018, 02:17:42 PM »
Death caps/stinger switches need to be removed and mains line cords rewired with chassis bonded to safety ground
John Roberts
http://circularscience.com
Tune it, or don't play it...
Recording Engineer
Re: bill whitlock
« Reply #22 on: December 11, 2018, 02:23:26 PM »
The studio owner has quite a collection of old guitar amps, so that is one thing that still needs to be looked over on an individual basis. We also have a bunch of dirty, unbalanced 120 power all throughout the studio as well.
JohnRoberts
Re: bill whitlock
« Reply #23 on: December 11, 2018, 02:47:46 PM »
In case I am sounding like a broken record a GFCI protected outlet can prevent the death caps from actually killing anybody, while the 6 mA threshold can still be enough to sting you.
They make GFCI protected outlet strips, but I worry that musicians would just plug around a tripped GFCI outlet strip, before taking the old soldier in for repair/rewiring.
John Roberts
Recording Engineer
Re: bill whitlock
« Reply #24 on: December 11, 2018, 02:53:49 PM »
All outlets are GFCIs... Code around here now days.
pucho812
Re: bill whitlock
« Reply #25 on: December 12, 2018, 01:06:36 PM »
Where?
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
Recording Engineer
Re: bill whitlock
« Reply #26 on: December 12, 2018, 01:46:28 PM »
Most everywhere, as it’s permitted as a garage.
JohnRoberts
Re: bill whitlock
« Reply #27 on: December 12, 2018, 01:48:08 PM »
Code for new buildings does not affect all legacy venues.
John Roberts
pucho812
Re: bill whitlock
« Reply #28 on: December 12, 2018, 02:06:39 PM »
hmmmm.  so how does that work exactly. My understanding of GFCI's is that the first outlet in the row is GFCI and the rest are not.  am I missing something here?
JohnRoberts
Re: bill whitlock
« Reply #29 on: December 12, 2018, 02:13:08 PM »
GFCI outlets have a pass through so you can protect a couple outlets with one, but to protect an entire branch you need a GFCI breaker in the panel.
[edit a less obvious issue the ground leakage is cumulative, so a few in series could be easier to trip, like in a studio full of legacy guitar amps.  ::)  [/edit]
« Last Edit: December 12, 2018, 06:43:06 PM by JohnRoberts »
John Roberts
abbey road d enfer
Re: bill whitlock
« Reply #30 on: December 12, 2018, 02:39:44 PM »
It should, but some folks are quite finicky about the correctness of their vintage gear. For them, I can only recommend a safety isolation transformer. The capacitance between primary and secondary is minimized (<120pF in Europe) and the secondary is floating, i.e. none of the wires is connected to neutral. The amp may hum, but it's very easy to provide an earth connection to the chassis.
"The important thing is not to convince, but to give pause for thought." (B. Werber)
pucho812
Re: bill whitlock
« Reply #31 on: December 12, 2018, 06:33:33 PM »
thank you JR
Speedskater
Re: bill whitlock
« Reply #32 on: December 14, 2018, 07:49:48 PM »
I have not seen any new papers or blogs from Bill Whitlock is some time now. Will this pdf be posted anywhere?
Kevin
pucho812
Re: bill whitlock
« Reply #33 on: December 14, 2018, 08:27:19 PM »
Yes the moment I get it. Mr Whitlock is currently in the middle of a home move, when he gets unpacked, I'll have it
Last post August 11, 2006, 05:21:07 PM
by Bookkeeper
Last post November 19, 2016, 07:59:48 AM
by mhelin
Last post September 29, 2007, 05:12:14 AM
by Freq Band
Last post February 07, 2010, 01:45:36 PM
by radiance
