untune
Hi all,
I've been fitting a Sifam AL19 retro VU meter into a preamp project. There are two surface mount LEDs inside it, with s 330ohm CLR between them, and positive/neg wires to hook up to a power source. The sticker is a bit damaged but I believe it says 12v, 20mA.
The power transformer has an unused heater tap that used to be for a first stage valve - I moved this to a 6.3v tap, freeing up the 5.7 (0.3A) tap.
I would like to use this to power the LEDs. I have hooked the VU meter up to a 9v battery and it lights fine. Last night I hooked it up to the 5.7v tap with a small circuit I found on another site consisting of a 1N4004, a 10uF electrolytic cap across the supply and a 200ohm resistor (didn't realise there was a CLR inside the VU at this point).
The VU lights up fine, perhaps a very very subtle flicker.
I'm wondering - is this safe to run, and is there a better way to get DC to run the light from this tap?
Thanks for any input
