That's interference from all the crap from switchers, cellphones, WiFi... whatever. Just discount it.JAY X said:Hi!
I wrote mhz, but i would say MHz,...megahertz.
That is the problem writing on a mobile phone... sorry!!
Jay x
All I can see is some signal in the MHz range, almost certainly picked up by the test cords. Not hum nor ripple.JAY X said:Hi,
Below is a link for the pdf with ripple and noise measurements. The attachements does not work...
I said MHZ, but really was khz....sorry...my fault! I think i confused the bandwidth of the picoscope, with the measurement. :
Jay x
download link:
https://mikrosum.webnode.es/_files/200000019-4a1984b0fa/VOLTAGE%20DOUBLER%20PSU%20RIPPLE%20V4.pdf
All these measurements are meaningless to me. I don't even know what you're measuring; is it the supply rail noise or the device's output noise. Anyway the waveforms do not look like hum/ripple.JAY X said:Here are some measurements i did with another CRC filter: 470uf/22R/470uf. These measurements are in ms.
There is no way ripple on the supply rail can result in BW limitations; look elsewhere.I really thought that my problem with the frequency response at both low and high end were due to the noise of psu...but perhaps the cause is other...
I don't really understand what you man, can you post this schemo?JAY X said:Hi!
Well... not so fast...
I was reviewing the schematic from the presonus eq3b, that i found in among the thecnical documents, and from the schematic It seems there are two Ground areas so to speak:
1. At the AC inlet.
2. From the filter caps towards the DC output, a shared ground.
So, both grounds are separated. This is my interpretation from the schematic. But i don't know if this is correct.
Thank you for your advise.
Jay x
Wrong interpretation. The ground symbol is a simplification that indicates that all the points that carry this symbol are electrically connected together. In reality there is a small resistance and inductance between all these points, but one may assume they are negligible; at least, that's what the designer assumes.JAY X said:I was reviewing the schematic from the presonus eq3b, that i found in among the thecnical documents, and from the schematic It seems there are two Ground areas so to speak:
1. At the AC inlet.
If you use a metallic enclosure, this is mandatory. Best choice is the 0V connection to the rest of the circuit.JAY X said:Ok.
Another question.
Should i tie any part of the PSU Ground, maybe from filter caps or the DC output, to chassis?
Jay x
