untune
Hi all..
I started a preamp project a while back, I'm currently trying to finish it off and build a case for it and I'm going over the design to see what I might be able to improve.
So the second channel is intended to be an instrument amp for bass guitar, straight into a triode connected 6au6. It has more than enough gain but I was curious about the grid stopper, and I chose a 1k2 resistor (can't remember why, likely naively borrowed from another design). Going off bass/guitar inputs this seems a small value. Calculating the miller capacitance for a triode 6au6 I get around 68pF give or take. Combined with the stopper that should give me a LPF with a cutoff of almost 200kHz if I've worked it out right. Seems extremely high.
Calculations again suggested than my ideal grid stopper would be around 120k, which I guess would add too much noise.
An example I read using a 12ax7 (which has a miller capacitance of approx 192pF) suggested the solution would be to pair a 10k resistor and a small cap of 100-470pF before the input to lower noise and create a more fitting low pass filter for input RF interference.
I applied the same logic to my 1k2 and worked out I'd need a cap of about 3000pF to 5600pF for a reasonable filter cutoff.
I expect that there's a disadvantage to having additional capacitance there and I'm curious what the ideal tradeoff is in terms of which component values to choose here. Are there any rules to follow?
Cheers!
Cheers!
