Sennheiser/Grundig DIN and Tuchel Connectors
bxt403
Calgary, AB Canada
I was wondering if anyone knows and can share the modern part number  for a 3 pin DIN connector that plugs into the one found on mics like the Sennheiser MD-441N and the Echollette ES14.
I'm not referring to the larger Tuchel connector like the one that's on the MD-441 2.
The 441 manual specifies the connector's in accordance to DIN 41524 and DIN 45594.
The specific connector I'd need would have to be a barrel female type that plugs into the male connector on the mic.
Any help is greatly appreciated.
Might this help?
https://www.ebay.ca/sch/i.html?_odkw=din+xlr&_sop=15&_blrs=recall_filtering&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=tuchel+xlr&_sacat=0
Or alternately:
https://www.ebay.ca/sch/i.html?_odkw=DIN+41524&_sop=15&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=DIN+%2841524%2C+45594%29&_sacat=0
https://www.ebay.ca/itm/1-x-Tuchel-Circular-Connector-DIN-3pol-Neumann-Sennheiser-T-3261-001-female/283295118010?hash=item41f5b472ba:g:biQAAOSwEK9T8HOz:rk:7:pf:0
Khron said:
Might this help?
Or alternately:
I was hoping to get a Mouser/Digikey/Farnell part number but I guess the connector's too old to be carried by the aforementioned suppliers.  I suppose I shouldn't be surprised that the price of the connector seems to be as much as getting a pre-made cable.
Considering I've dealt with them before: I guess my best option is Madooma in Germany.
Thanks.
I'd be quite willing to guess that it's definitely not being manufactured anymore. Well, there might be some small-scale operations in China, but that's a crapshoot either way.
Tuchel seem to have merged with (a part of) Amphenol, but they only have an "automotive" and an "industrial" section on their site, so...
"Hirschmann" and "Lumberg" are the brand names you should be looking for and the type is "DIN connector" ("Mini-Tuchel" was never a valid name for this type of connectors):
I don't know where you are living but here are two german sellers  (there are more):
https://www.henri.de/bauelemente/steckverbinder/din-audiostecker/din-kupplung-schraub.html
https://www.buerklin.com/de/din-steckverbinder/c/40131200
BTW, a 5pin 180° female DIN-connector will fit on a 3pin male too.
