Allen and Heath Mix Wizard 12M pre/post send solder pad labels
Potato Cakes
Nashville, TN
Hello, everyone,
I have a Mix Wizard 12M that I using as a basis for a studio cue system. The manual shows which solder pads on the channel cards to connect to change aux 5-12 between pre and post send, however the schematic labels in the manual don't seem to correspond to the actual channel PCB silkscreen. Before I do some good old fashioned trial and error, I was wondering if someone here has indeed changed the aux send pick off points and which solder pads are to be changed.
I did email Allen and Heath a while back but I have not heard anything yet.
Paul
I went ahead opened it up. As I suspected, the lettering on the cards did not match the schematic in the manual. Looking at the solder traces it was easy to figure out the ones I needed to change. The schematic also shows jumper setting for the direct outs, which are not on this desk. I was impressed at how much they crammed in such a small space. The solder pad design was a pretty smart way to get around the need for headers and jumpers.
Paul
The four solder pads on the left are the ones of interest. From left to right, 1 and 2 are pre/post for Aux11&12 and 3 and 4 are for Aux 5-10. The foremost card has the correct solder pads connected for prefade sends.
Hope this helps someone.
Paul
