BluegrassDan
Triple triode tubes?
« on: December 22, 2018, 07:29:02 PM »
Has anyone experimented with triple triode tubes like the 6AC10? I just aquired a bunch and wondered if they could be at all useful.
Re: Triple triode tubes?
« Reply #1 on: December 22, 2018, 08:20:58 PM »
I saw some used as moving coil meter drivers in a Brennell reel to reel  I have , I forget which type they were at this stage ,I think they were just paralelled up  with the meter in the anode circuit .
Matt C
« Reply #2 on: December 22, 2018, 08:38:29 PM »
I haven't really experimented with them but I see them all the time in old Ampeg amps I'm fixing (they used the 6K11 i believe).
abbey road d enfer
« Reply #3 on: December 23, 2018, 07:57:25 AM »
It seems to be very close to 12AT7, only 3 sections instead of 2. Not the most commonly used tube in audio applications. 12AT7 is almost exclusively used in the phase-inverter of push-pull amps. Could be used as a hefty line output stage, maybe...
"The important thing is not to convince, but to give pause for thought." (B. Werber)
mjrippe
« Reply #4 on: January 09, 2019, 06:24:30 PM »
There are compactron triple triodes of many types including 12AT/U/X7 in various combinations.  Here is a link to a great PDF: https://www.dropbox.com/s/h4goh9wqj6oxvf2/Compactron_Survey_v1-06.pdf?dl=0
BluegrassDan
« Reply #5 on: January 09, 2019, 07:18:39 PM »
Thanks for the link!
buildafriend
« Reply #6 on: January 09, 2019, 07:28:10 PM »
compactrons seem to be a limiting factor for many tube testers
rackmonkey
« Reply #7 on: January 09, 2019, 11:21:12 PM »
Indeed. Even most of the better Hickok models require an add-on adapter unit to test them.
I once got a box of tubes with several 6EZ8s in it. One of the few non-compactron triple triodes.  The 3 triodes are identical and have electrical characteristics between a 12AU7 and a 12AV7, if I remember correctly. I played around with using it in a guitar amp with a tube tremolo circuit in it. I thought using those triple triodes might beat either having to use hard-to-find single triodes or wasting half a dual triode for the tremolo circuit. But in the end I abandoned the project because if one triode gets weak or fails, I’d have had to replace all three, regardless of their individual conditions.  Didn’t seem economical to me. I ended up settling on 6AV6s for my simple tremolo units. Plentiful and cheap as dirt.
But if you’ve got several you might consider going ahead with a project and living with the limitation above, at least until you run out of them. From there, you can always convert it to use more common tubes, I guess.  Just a thought.
« Last Edit: January 09, 2019, 11:25:20 PM by rackmonkey »
Whether you think you can or you think you can't, you're probably right.
« Reply #8 on: January 10, 2019, 04:08:35 AM »
I was comissioned to design a phono preamp using one compactron for each channel. Not sure what more you're expecting, it's just three 12AT7 triodes in one bottle *shrug*.
abbey road d enfer
« Reply #9 on: January 10, 2019, 04:58:29 PM »
Seems to me like a very strange commission; no performance target, only a big constraint...
mjrippe
« Reply #10 on: January 12, 2019, 03:51:41 PM »
Yes, but this is GDIY!  I have a military TV-7 tester and I just built a compactron socket into a bud box with a rotary switch.  A multi conductor wire goes to a plug with a nine pin miniature base.  Plug in the 9 pin and set the tester for the first triode of the 12AX/T/U/whatever.  Then use the rotary switch to select triode 1, 2, or 3.
« Last Edit: January 13, 2019, 09:36:26 PM by mjrippe »
« Reply #11 on: January 13, 2019, 12:14:12 PM »
Apart from the issue pointed out below, IE that if one valve goes weak you have to replace the valve, it's still a useful valve. The  6AC10 has high u/gain - 62, lower than a 12AT7/ECC81 but not far off a 12AX7, one 6AC10 and you have a high gain IP stage and LTP all in one, saves space, meaning the amp chassis can be compact.  If you have four or so and build an amp, two in the two as spares it'll last a good few years. Still, it means you have to buy "special" valve bases which are probably more expensive than your average B9A or octal. Am pretty sure I've seen them used in a few headphone amp design's.
If you don't use them the prices of these have gone up like all valves, some folk love em and they can fetch a good few bob, so not a bad find.
Andy.
abbey road d enfer
« Reply #12 on: January 13, 2019, 07:44:49 PM »
You must have your references mixed up; 12AT7, Mu=60, 12AX7, Mu=100.
buildafriend
« Reply #13 on: January 13, 2019, 11:41:23 PM »
I was looking at TV 10 testers. Good idea with the DIY compactron adapter. I use a Hickok 532, but I want a mu tracer. It’s nice to be ready for anything
btw we’re both brooklynites. Let me know if you’de like to grab a drink and geek out
All the best,
Last post April 05, 2005, 01:56:55 AM
by PRR
Last post January 17, 2006, 03:38:20 AM
by AudioJohn
Last post June 27, 2010, 12:55:27 PM
by andre tchmil
Last post July 24, 2018, 03:29:48 AM
by rock soderstrom
