ComodoComplex
Hi all,
I have a Sony C37A on my bench which is experiencing an intermittent pop. This problem has been present for a while. Previous work done to address it has been replacing of the tube in the mic with a NOS variety and replacing all cabling to the mic and from the PSU (a CP-3). None of these have actually alleviated the problem, and the pop is so unpredictable and rare that it is hard to know if the problem is really fixed after attempting a repair. Unfortunately, it is almost certain to crop up in a recording session, which is unacceptable.
The recording engineer showed me the pop waveform in ProTools, and it resembles a sharp transient followed by a damped oscillation. This leads me to believe it is an issue with the high-voltage caps in the power supply. Perhaps one of them is failing, experiencing a brief short which destabilizes the supply. Then, as is the nature of second order filters, a damped resonance occurs to return the state back to equilibrium. Does this theory hold any water?
I ask because replacing the three 20/20uF 350V can caps with a suitable NOS variety (a nice drop-in replacement which will retain the authenticity of the vintage gear) is going to be a somewhat lengthy and expensive undertaking... I am prepared to do this, but second opinions are greatly appreciated! I've attached the PSU schematic here for reference.
Ben
Ben
