abbey road d enfer
Re: "squeeling" noise in mic preamp
« Reply #20 on: January 01, 2019, 06:50:58 AM »
Case is not but the screen pin is. I can try to ground the case also.
Check continuity of the ground pin with the case; sometimes the ground pin is connected to an internal electroastaic screen only.
Regarding the That 1646, i didn't actually know that.
It's in the datasheet...
What are my options in that case? I could use a lower pot, 5k for example..
You may not notice a problem, because it just ruins the CMRR, which is not immediately noticeable if you have a relatively clean environment. Even with a 5k pot, CMRR would be just about 20dB.
If you want the 1646 to work as it should, you should precede it with a buffer.
"The important thing is not to convince, but to give pause for thought." (B. Werber)
aviel
« Reply #21 on: January 01, 2019, 10:53:08 AM »
I am feeding it with a single unbalanced signal, so CMRR here will help only if the same noise is present in my ground also.. A buffer can be a good idea anyway.. Just a TL071 or rather another jfet?
abbey road d enfer
« Reply #22 on: January 01, 2019, 11:55:44 AM »
I don't get it. Do you mean "feed it to an unbalanced input"?
Do you know a connection to an unbalanced input can be improved by driving it with a balanced source, provided the wiring is also "balanced" (2-wire+shield)?
Almost any decent audio opamp is suitable, since there is no issue with S/N and the 1646 presents a moderate load, that a TL071 can easily handle.
aviel
« Reply #23 on: January 01, 2019, 12:15:36 PM »
What i mean is that my gain stages are not outputting differential signals, so that 1646 is getting a monolithic input (the inverted input is connected to the ground) therefore the CMRR is less significant here is assume
abbey road d enfer
« Reply #24 on: January 01, 2019, 03:32:11 PM »
Why do you do that? Seems silly to me to use a good balanced driver and use it unbalanced, when a simple voltage follower could have done it better.
aviel
« Reply #25 on: January 01, 2019, 05:00:28 PM »
I use it balanced. It is outputting a balanced signal.
abbey road d enfer
« Reply #26 on: January 01, 2019, 10:45:42 PM »
OK, now I understand what you mean. The 1646 receives an unbalanced signal so , yes, is second input is grounded; that's the normal operation in most cases.
But I was talking about output CMRR. Having a non-zero inpedance driving the non-inverting input of the 1646 is a cause for impairing its output balance, which in turn results in poor CMRR.
aviel
« Reply #27 on: January 07, 2019, 01:57:28 PM »
Quick update:
I added a TL071 buffer to drive the line driver and indeed the squeelibg dissapeared! Might be related to other stuff, since i moved some parts on the layout to make place for the buffer.. :)
Last post September 24, 2005, 02:47:29 AM
by adamasd
Last post August 29, 2007, 11:46:57 AM
by Minion
Last post May 28, 2008, 06:32:39 PM
by Denyle Guitars
Last post November 15, 2010, 07:57:28 PM
by CurtZHP
