dbonin
LOT of FOUR (4) Meters
Panel VU Meter TN-73 0dB=0.8VAC size=76x59x41mm & LED lamp NISSEI
Can be used in DIY audio applications.
These are new in the box, never used.
no external resistor,diode required
Out of the box, the meter will "zero" 0dB at 0.775 VAC
Add a 3.6K ohm resistor to zero the meter at 1.228 VAC
Images:
https://ibb.co/gDF3NpJ
https://ibb.co/jWwpswL
Images:
