Fireface 800 disassembly
pvision
Brighton, UK
I have a broken pot on a Fireface. The front panel doesn't want to come off because the push release on the XLR inputs won't allow it to slide forward over the pot shafts
Logically there must be a way to remove the spring-loaded locking release tab but I can't see it. Any ideas?
The XLRs are Neutrik PCB-mount 3-pin XLRs with a metal release tab. Part number is probably NC3FAH. I can't find any useful info on the Neutrik site
https://www.neutrik.com/en/product/nc3fah
Nick Froome
OK, more Googling led me back to the Neutrik site. There is a tool to remove them. It is around 12 mm long and about 0.8 x 1.2 mm. I have a jeweller's screwdriver of approximately the right size but it's too short
http://www.neutrik.us/en-us/support/faq/can-the-latch-of-a-xlr-chassis-connector-be-removed-and-replaced
Nick Froome
Maybe try the screwdriver from the front...... Just aim down a bit and leverage it...... not sure it makes sense how I'm describing....but it has to go down and out..... at least on some other models....
