Ribbon - question about motor construction
« on: December 28, 2018, 04:43:05 PM »
Hello and thank you for your help.
I am building a Ribbon motor and trying to understand the following:
My motor body is made from steel and the corrugated foil is made from aluminum.  should i connect the foil strip directly to the steel motor body or i should create a separation ? I am referring to the top and bottom parts where the wires connect to go to the transformer.
What option should i go with ?
1) Motor body --> Foil --> PCB (Double sided connected to the wires)
OR i should do
2) Motor body --> PCB --> Foil -- PCB (Double sided connected to the wires)
I hope that my question is clear enough.
Thank you !
Tom
Last post March 20, 2006, 07:13:09 PM
by northsiderap
Last post August 10, 2006, 12:18:04 PM
by clintrubber
Last post December 24, 2007, 03:51:55 PM
by Marik
Last post November 14, 2009, 12:26:49 PM
by Marik
