L + R button panpot circuit
boji
Maryland, USA
Hello friends.  I was thinking of using relays to engage a panning circuit when both 'left' and 'right' buttons are pressed in my group cards.
When either left or right are pressed (but not both), it removes the pan circuit, and sends L or R output directly to program bus.
I think Ian mentioned Neve used this method back in the day, but they had a trick way to do it (possibly created by Ian?) in that it avoided relays.  Ian, if you're out there, do you recall how they did it? If not or if it requires 6 pole switches I'm comfortable going with relays.
My question is, does anyone see a problem with circumventing the pan circuit with regards to volume level?  I imagine signal hard panned would be quieter than a left or right direct output going to program bus.  Should I offset that with attenuation resistors or just leave the louder (slightly less noisy?) signal in play and pull down the fader if required?
I've never designed a panning circuit but I think it depends on whether the source signal in question is mono or stereo, ie. whether you're sending it to the left channel only or just the left channel (since it may contain a very different level signal than the right)
In mono operation you'd essentially be splitting the signal in two paths and varying their resistance and their sum would be (depending on the taper used) very close the same with a linear pot.
With a log pot in theory you'd have the "middle" somewhere around 1-2 o' clock. I've seen special taper pots being sold (S-taper, anti/reverse log etc) which are specifically designed for panning, but they're no use to you since you're looking to L/R with switches/relays.
You could do it with DPDT switches. See attached for one conceptual way (you could take the pan circuit send from either switch).
For the panning,  first decide a pan law,  3dB is common,  then make all the levels match, L switch and hard panned L should be the same level.  You could use different size bus feed resistors to match the levels if necessary.
I like the idea of bypassing the pan pot,  but maybe implement center as well?
I've read people do the center dent with blobs of solder.. bypass is in my opinion sort of useless.
Thanks  Efinque and 12AX for your ideas!
Thank you for the diagram!  If I am looking at it correctly, engaging either left or right switches would leave the panpot outputs still in circuit with a return path to ground. However i'm not confident a 'true bypass' would be entirely beneficial. I'll draft up what I have so far and post it in a bit, that way we can appreciate how simple and clean yours is in comparison.  :)
You know, I hadn't even considered that, thanks! Yes why not, since I'm already going whole-hog with bypass.
Depends on your intended goal. The advantage would be not going through additional circuitry, extra noise and distortion which can add up over multiple channels. Plus you get true and precise panning with switches, which is often not the case with a pan pot.
Yes the pan outputs would still be connected, it was more a quick sketch to show the sending part. With pushbutton switches you can get more poles and use them for a true bypass, which is probably a good idea, one less stage adding noise.
Thanks John. Ok shooting for center and true bypass,  I rushed this and it's late, but draft attached:
I suppose I could do without the two extra input relays, instead just connect to switches.  ::) ::)
Like I said it's late.  ;D I suppose the only value would be the panner is way on the other side of the card near the TX output,  far from the switches. Relays would reduce the signal trace length and remove vias.
Edit: Ah! Not if I move the pan switches above the panpot!  Hmmm
Also (just spitballin')  maybe it's more intuitive to have buttons off mean the panpot is engaged, and both L/R buttons on, be center?
I find it most intuitive like it is done in a VR Console:
One button for each bus, and one button to activate the panpot.
I did indeed invent such a circuit back in the mid 70s. Even in those days, front panel space was at a premium especially on custom consoles. The standard set up at Neve at that time was routing buttons plus a pan button plus a mute button. I was a year out of university and we had been taught all about these new fangled logic circuits. So I drew up a truth table and worked out the switching to achieve it. Attached is a schematic of the version I used in the EZTubeMixer design using toggle switches. With both toggles up the channel is muted. With either one down the channel is routed straight to a bus. With both toggles down the pan pot is engaged.
Quite a sleek and simplifying circuit.  I appreciate it Ian!
As an aside, my channel cards are packed too tight, but group cards are the opposite, with lots of empty faceplate- almost too much...  It has me leaning towards the extra pan button now.  ::)
I wish I could backtrack and increase the face plate size of the channel cards, as I'd definitely have added your pan idea to it.
I'm sure I'll return to it for another project down the road.
Thanks again for sharing it!
VCA panning circuit?
Don't listen to me though, I've never built one.. you'd probably need a control voltage to an IC or something but at the cost of fidelity (and it sort of makes things complex, as well as some basic IC's only have mute)
Pan pots can get very crackly as they age though (I have a DJ mixer from the 90's)
VCA. No reason not to use VCAs.
With a bit of thinking, you could use a pair of VCAs to do fader, pan and mute. It's a matter of getting your control voltages correctly scaled for the required functions. If you get really clever, feed the VCAs from a dynamics sidechain as well.
JR and Wayne had some detailed musings on an all VCA approach to pan/fade/mix over at proaudiodesignforum.com several years back.
I guess I've had this running belief that VCA's have not improved over the years.  :D
Thanks I'll try to locate the thread.
I must confess keeping it mechanical has an appeal to me that fits with my level of competency while also ensuring a clean signal path.
I can't even imagine what that would do!  Are we talking dynamic pan/width ? Or just that it allows you to also have a dynamics processor included as part of the bargain?
That is not true. The 2181 is actually significantly better than the 2151 of yore.
IMO you're making it too complicated. There is nothing wrong with having the panpot permanently in circuit.
The only possible issue is that attenuation of opposite side when panning hard is not sufficient. That's where the active panpot created by Doug Self excels.
EDIT: I see you use a weird panpot arrangement that is in shocking contrast with the level of dedication you put in this project.
That is not true.
Figured as much.  Superstition is not a positive personality trait.
You're right.  I have the compulsion to add buttons since the group card looks naked in comparison to the input card.
