alexandronozeolu
New member
- Joined
- Oct 29, 2018
- Messages
- 4
Hi everyone!
I just finished my GSSL Compressor, it works fine.
I measured the frequency response of analog device in comparison with ssl emulation plugins.
I found that the analog has a +3.5 db high shelf.
You see it in the picture below. Red is an analog and purple is a plugin.
This is normal?
A higher frequencies boost audible to the ear a little and everything else is ok.
How to correct this non-linearity?
Maybe i can change some resistor values in input/output buffers?
Thanks for the help.
This is normal?
