substitute
OPA2132PA getting hot in a Trident series 65
« on: January 08, 2019, 08:49:35 PM »
Hi, I've been recapping a Trident 65, the owner wanted to try out a better opamp in the line amp position (IC 1). In googling about possible upgrades I came across this thread that suggests replacing the line and mic opamps with an OPA132...
https://groups.google.com/forum/#!topic/rec.audio.pro/YNoab0to69s
I swapped the two opamps tonight, fed a test tone to the line input and put a scope on the direct output. It passed signal normally but after a few seconds I noticed that old familiar burning smell, and discovered that both the mic and line opamps were very hot to the touch.
As best as I can tell they should be compatible, any advice on figuring this one out?
Here's a link to the manual, input channel schematic is on pg 63...
http://thehistoryofrecording.com/Manuals/Trident/Trident_Series_65_Manual.pdf
substitute
Re: OPA2132PA getting hot in a Trident series 65
« Reply #1 on: January 08, 2019, 09:14:40 PM »
DUUUUUUUUUUHHHHHHHHHHHH
TL071 and OPA2132 are totally different.  :-[
pucho812
« Reply #2 on: January 08, 2019, 11:30:37 PM »
The tl071 is a single channel
The tl072 is a duel channel
Opa134 is a single channel and can be a sub for a tl071
The opa2134 is duel channel and can sub for a tl072
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
substitute
« Reply #3 on: January 09, 2019, 10:25:26 AM »
Yeah once I figured that out I was gonna delete the original post, but better to leave it up as a cautionary tale should anyone else stumble down that path.
JohnRoberts
« Reply #4 on: January 09, 2019, 10:26:31 AM »
Taking one for the team....  8)
John Roberts
http://circularscience.com
Tune it, or don't play it...
pucho812
« Reply #5 on: January 09, 2019, 01:16:51 PM »
We all have put in a wrong chip at least once,  it's because they all have the same foot print.  Similar to putting in an  polarized cap backwards, it happens at leas once..
scott2000
« Reply #6 on: January 09, 2019, 04:07:27 PM »
Chip backwards one time here...... ruins it pretty fast.... :-[
and....
an earlier Mytek  I've seen has a socket one direction but the chip needs to go the other way..... tricky
I recently found an error in an older TL Audio compressor....the pcb has the cap marked wrong and the cap is installed that way..... guess it's not critical... Coupling cap?......still works but it's there...
pucho812
« Reply #7 on: January 09, 2019, 05:50:05 PM »
Chip in backwards and seconds later boom.  Chip cracked in half
substitute
« Reply #8 on: January 09, 2019, 08:22:35 PM »
I recently smoked a kurzweil k2500 trying to instal a scsi cf card reader in place of the floppy drive. Turns out that kurzweil did their scsi connections backwards.  :'(
I'll get a thread going about that eventually, right now I just want to throw the thing in the trash.
Last post May 14, 2007, 03:46:18 PM
by dissonantstring
Last post September 20, 2008, 03:23:48 AM
by CJ
Last post August 09, 2010, 11:33:53 PM
by QUEEF BAG
Last post February 25, 2012, 12:53:49 PM
by jsteiger
