UTC A-25 Plate to Line Blueprint
CJ
GDIY Supporter
California
rework of old print
finding the lams could be a problem
could fit on a 50 EI lam if you use a nylon bobbin and play with the wire sizes (drop down a gauge)
no tear down pics at this time...
https://img1.wsimg.com/blobby/go/0e07cc59-2f5a-481f-967d-12c7363b86fa/downloads/1d0thj5dj_385871.png
how is the "x" aquired? Is it a point inside? is this the air gap I've read about?
Also, I've read about adding a virtual center tap to single ended secondaries.... Is there any way to do one on the primary side??? I'm guessing there are reasons not to... Just curious..
And why is aquired and attenuator spelled wrong here (red squiggles) ...... used to be impedance too iirc but it seems fine now???
Cool, cool. Thanks, CJ! Keep em comin.
what method of measuring primary inductance have you settled on these days? So many techniques discussed over the years.
fixed the print marked "splice x"  and adjusted inductance as this is a gapped core , doh on me,  :eek:
A-26 is similar only with non gapped core  and it has a CT for P-P operation ala Pultec EQP
<used in the Pultec MEQ-5>
Where? I though MEQ-5 used Triad HS56 and HS50. No DC.
man i am getting old that's right Triad HS 50,
HS 52  and UTC  A-26 in the Fairchild, A-24 in the LA2a, right?  :p
A-25 in the Collins perhaps?
don't know which chassis ,  howabout Gates, could i get a list of every transformer they ever used please?  :D
