For Sale NI Maschine MK1 + Kore Interface
Hi Christoph !
Do you know if the WTCP51 iron is compatible with the older TCP-Magnastat 24V/50VA stations (which i have )
the connector seems to be different , otherwise they look the same ?
in fact i would only need the plastic handle . the screws that hold the heater element to the handle got loose.
Hi!
according to specs they should be compatible; the newer base station still delivers 24V and the iron is rated with 50W. It looks like there's no connector on your unit and the cable is connected via a screw-terminal?
best regards,
Christoph
Hi cristoph
I do have a connector , some kind of 3 pole DIN-Plug with only 2 pins connected .
Yesterday however my basestation started humming (nothing serious , just a loose screw on the transformer maybe ) but  i´m considering one of your stations .
Can you do a GDIY-friends-price with shipping in Austria ?  ;)
David
