rogs said:I've found something like this works well ......you would need to select R14 to suit the volts you want to appear across R1.....
Khron said:Got a datasheet for that "measurement microphone" (capsule)?
I'd argue the idle current is more critical than the voltage or resistance value. But what do i know? It's not like Ohm's law is worth anything, right? ;D
And out of sheer curiosity, what are some of those "minor mistakes" on the ESP project page (or did you mean on the AudioImprov page)?
n3mmr said:He says one should make a resistor 1k for unity gain but it should be made 10k. R8, I think.
Khron said:It helps if you read the entire text, in context.
http://sound.whsites.net/p93-f7.gif
"Although U1A is shown with a gain of 2, this can be reduced to unity by removing R8 and shorting R9 so that U1A is a unity gain buffer."
Khron said:That looks 90% identical to the circuitry inside the BM700 / BM800 mics.
I'm still not quite sure what's with that 2.7k as the only possible drain resistor there, but maybe i'm just weird like that...
