Did i just break it?? (Lundahl LL 1540)
weiss
Germany
I desoldered some LL1540 from a board. One of them didn't want to go off easily and the ground leg broke ??? I can't really see where it connects..
Can i still fix it??
Help!
I don't think you can fix it but the transformer will work without it.
Not with 100% Performance but the 97% may still be fine.
(Check at another transformer if the case is connected to that pin too. If yes ground the case)
Thanks Volker!
Yes it grounds the case, i‘ll try if it works anyway.
