Below are two of the lightbulb limiters used by Hammond , fed from the console amp which was usually 4xEL84 into 8ohms .
I see one has single bulb the other dual .
Ive used a simple 200 ohm wirewound pot before as input attenuator for a spring , runs ok off anything from solid state op amps to big guitar amp speaker outs .
I found some dual wirewound pots and was wondering if it would be possible to combine the lightbulb lim and a variable attenuator using the two pots . With the lightbulb limiter followed by the simple 200 ohm attenuator as soon as any attenuation was dialed in their wasnt enough current to light the bulb anymore .Could I simply replace the two resistive elements in the hammond drawing with two pots ? The bulbs could be bypassed with a dual pole switch when limiting wasnt required . I can see with the simple 200 ohm pot method the load impedance of the source amplifier varies quite a lot dependiing on position of the dial ,that hampers the action of the lightbulb , so maybe the twin pot could form a kind of interactive threshold control between current through the bulb and limiting action on one hand and output level to the spring on the other .
Star, delta, bridge, t section attenuator ,theres just to much going on for me to clearly visualise whats happeneing to the impedences , maybe someone could explain better dual pot attenuators and how it might work inside a bulb bridge .
