WTB Metal knob set for 33609
Potato Cakes
Nashville, TN
Hello, everyone,
I'm completing a 33609 build and I'm trying to find some aluminum knobs for the controls to make it look like the metal knob version. I've found one place that has something close to what I'm after, but they are only 4mm shafts and I would need 1/4" and 6mm. Worst case I could drill them out but I would check here first to see if anyone happens to have to have some or can point me to a supplier.
Paul
Will these do?
The one on the top is plastic inside, aluminium shell. 11mm diameter for 6mm D shaft. Pointer line options are black, red, green, blue.
The one on the bottom is solid aluminium 15mm diameter with grub screw for 1/4" shaft. Pointer line options are  black and red.
Not quite what I'm looking for. I'm after something like this:
https://www.rapidonline.com/mentor-aluminium-turning-knobs-with-collet-fixing-anodised-545462
But with cap instead of black.
Paul
Have you already browsed through digikey? They have a very large selection of aluminum knobs by Kilo International, I know this is not exactly what you are looking for but as an example: https://www.digikey.com/product-detail/en/kilo-international/ML-90-3-7/226-3028-ND/305260
Here's the whole catalog by Kilo: https://www.digikey.com/products/en/hardware-fasteners-accessories/knobs/568?k=Kilo%20International
I have looked through the Kilo line, and they make nice stuff, but it needs to be like the Mentor style with the collet and cap. I may be just customizing their product.
Paul
