vmanj
12AX7 question
« on: February 04, 2019, 04:21:47 AM »
Greetings to all.
I have a 12AX7 question.
I want to connect only one half of the triode.
What needs to be done with contacts that will not be used - connect them together or just leave them unconnected?
RuudNL
Re: 12AX7 question
« Reply #1 on: February 04, 2019, 04:25:29 AM »
Leave the unused pins open and don't use the filament for the half you don't use.
There is a solution for every problem!
http://www.vansteenisaudio.nl
Mylithra
Re: 12AX7 question
« Reply #2 on: February 04, 2019, 05:59:52 AM »
This is fine if your heaters are 6.3v. If your heaters are 12v, you'll have to leave that triode heater connected but you dont need to hook up the other 3 elements.
vmanj
Re: 12AX7 question
« Reply #3 on: February 04, 2019, 01:55:57 PM »
I see, thanks.
clintrubber
Re: 12AX7 question
« Reply #4 on: February 08, 2019, 07:33:26 AM »
That's interesting. I'm well aware of the three heater pins, but hadn't realized that beyond the 12,6 & 6,3 V possibility
it enables heating up each section separately.
So I figure the 1st section (pins 1,2,3) is heated by the heater connected between pins 4 & 9.
Nice, despite using tubes we can save a bit of energy here ;-)
Re: 12AX7 question
« Reply #5 on: February 08, 2019, 10:24:16 PM »
In the AKG C 12 Mike they tied cathode, grid & plate (anode) toground, in the unused half of the 12AY7 (6072) tube.
clintrubber
Re: 12AX7 question
« Reply #6 on: February 09, 2019, 07:12:25 AM »
Curious to the benefits, if at all. Or possibly just keeping everything tidy & defined, without much second thought (the latter not that likely though for such a company).
But in the unlikely case that any small tiny parasitics between the tube sections are playing a role, then they're increased by the ground-connections of the unused triode section.
scott2000
Re: 12AX7 question
« Reply #7 on: February 09, 2019, 11:23:23 AM »
this circuit leaves center tap unconnected and grounds one heater? This has to do with using dc??
Shows "one channel only"
Is the other channel using the same tube with this configuration left on heaters???
I'll say yes..... ok,,,,maybe?
« Last Edit: February 10, 2019, 10:36:27 AM by scott2000 »
abbey road d enfer
Re: 12AX7 question
« Reply #8 on: February 09, 2019, 12:48:10 PM »
In some cases, having increased but controlled parasitics is preferrable to random.
clintrubber
Re: 12AX7 question
« Reply #9 on: February 19, 2019, 12:02:57 PM »
Check!  :)
Mylithra
Re: 12AX7 question
« Reply #10 on: February 19, 2019, 02:01:29 PM »
You need 6.3v per heater triode. If you're running DC heaters at 12v, you have to have the heaters in series. If you're DC heater supply is 6v, your heaters should be parallel.
Last post January 19, 2005, 01:36:12 PM
by cayocosta
Last post October 02, 2005, 04:20:39 PM
by Hayman
Last post July 30, 2006, 01:02:35 PM
by EmRR
Last post April 09, 2008, 07:37:11 PM
by mattnj
