g9 interstage cap
phonodj
Member
Germany
hello
i´m building my first g9 micpre and have a question i didn´t found an answer in the meta for.
should the interstage cap be 220nF as printed on the board or 470nF as told in the part list?
best henning
Either/Or. You will not notice any difference. Whatever you have on hand.
Just make sure the voltage rating is at-or-above what is specified.
cj
I used 470nF for C3 and C103( from The Schematic )
That's work great.
[quote author="Minguta"]I used 470nF for C3 and C103( from The Schematic )
That's work great.
[/quote]
Can I ask where you got the decals for the front panel ??
I got layout from Frank.(Thanks a lot) :grin:
http://www.nrgrecording.de/diy.html
and print the layout to Transparent.
Do it like you make PCB. :razz:
PRINTING..
EXPOSURE...
DEVELOPMENT...
ferric chloride....ETC........ :green:
[quote author="Minguta"]I got layout from Frank.(Thanks a lot) :grin:
PRINTING..
EXPOSURE...
DEVELOPMENT...
ferric chloride....ETC........ :green:[/quote]
I have all the PCB making equipment. Where could I read more about what exactly is involved? Thanks ! :grin:
the 470nf if i remember correctly is the right cap to use there. this value will have a small effect on the tone of the preamp
very small, you could use almost any small cap... (well not any)
also, that is a neat method for the face plate. I'll have to figure it out and try it some time.
[quote author="WJS"]the 470nf if i remember correctly is the right cap to use there. this value will have a small effect on the tone of the preamp
also, that is a neat method for the face plate. I'll have to figure it out and try it some time.[/quote]
470nf in place of the 220nf you mean?
yes, the interstage cap. i believe 470nf is the right value tonaly. (not the 220nf) but both will work
