beatnik
Neumann KH120 studio monitor power supply repair
« on: February 11, 2019, 06:28:49 AM »
Hi everybody
I am trying to rescue a dead Neumann KH120 studio monitor that likely suffered from a power surge.
The SMPS has blown up and it is proving very difficult to repair it.
My first findings were disintegrated mains fuse and shorted switching mosfet. also one of the diode rectifiers on the transformer secondary was short circuit.
I have replaced the mosfet and the diodes, and also the pwm controller ic. I have checked all diodes, resistors and capacitors and also the opto transistor in the feedback path. Everything seems to be fine
When turned on the power supply fails to start, the voltage is trying to come up cyclically and there is a clicking noise at every interval.
My main worry is a shorted turn in the transformer, that would be impossible to replace.
Schematics aren't available for this unit as it's still in production.
Before I give up on this I was wondering if someone with more experience on SMPS repair can chime in and give some advice on possible things that can be checked.
Any help would be immensely appreciated.
scott2000
Re: Neumann KH120 studio monitor power supply repair
« Reply #1 on: February 11, 2019, 09:28:04 AM »
Is there a model number or any markings on the supply???
I'm just asking because some of them are pretty inexpensive?? The one in an Apogee Rosetta is like $10 for example iirc...
« Last Edit: February 11, 2019, 10:07:31 AM by scott2000 »
beatnik
« Reply #2 on: February 11, 2019, 02:14:26 PM »
That would have been great, but unfortunately the power supply is embedded on the same pcb as the amplifiers.
Seems to be a nicely designed board but unfortunately not very repair friendly. There isn't even a components overlay, not that would have been much useful anyway, since the manufacturer doesn't provide diagrams.
I have had a few smps for repair recently and didn't have much experience before. I have been reading a lot and watching youtube videos, there is a lot of information out there.
Unfortunately there is still something I am missing. It seems that the primary side of the transformer is sorted out, possibly there is something on the secondary that is clamping down the voltage as the power supply is trying to come up.
There are test points labeled +15V / -15V, could be worth trying to feed these through an external power supply and watch for current draw ? Next to these pads there are two more labeled +UB and -UB, I cannot guess what these are
beatnik
« Reply #3 on: February 11, 2019, 02:17:08 PM »
I have tried attaching a picture of the board but I get an error message saying my file cannot pass security checks. Weird. Yeah we know smps power supplies have dangerous voltages !
scott2000
« Reply #4 on: February 11, 2019, 03:24:39 PM »
Just a quick look I found this discussion about UB+....??
https://www.proz.com/kudoz/german-to-english/electronics-elect-eng/1257001-ub.html#2994859
Maybe someone can jump in who knows???
That stinks....... If it's your monitor I suppose creative thinking outside the box could be in order or a possibility if you can't get it sorted....
beatnik
« Reply #5 on: February 12, 2019, 03:46:00 AM »
Thank you. That likely means there are two separate +/- voltage rails
There is a 7815/7915 pair to regulate the +/- 15V rails. Maybe the +/- UB is the non regulated voltage before the regulators
The next thing I have to try is taking these regulators out and test them, it could be they have failed since there was a shorted diode on the secondary of the transformer
pvision
« Reply #6 on: April 15, 2019, 07:16:17 PM »
Did you get anywhere with this? One of my KH120As just failed with a blown fuse
The Mosfet is shorted but I haven't found any other bad components yet. I have a couple of mosfets to replace the bad one & plan to do this tomorrow
Nick Froome
beatnik
« Reply #7 on: April 15, 2019, 08:05:55 PM »
Very ashamed to say, but I finally gave up and sent it to Sennheiser UK to repair !
In my case the mosfet was shorted, and also one of the diodes on the transformer secondary. I also replaced the pwm controller ic since I had no means of testing it, but knowing from previous smps repair that being a common point of failure.
Check also the 7815/7915 regulators on the output.
I think mine had a problem in the feedback that sends the voltage back to the controller, or possibly a short in the DC-DC transformer
I managed to get the power supply starting without blowing the fuse, but the voltage would not come up and it just kept cycling on and off.
I really hope you can be more successful than me. It would be nice if you post any updates here.
pvision
« Reply #8 on: April 16, 2019, 06:04:09 AM »
I'm going to throw a Mosfet in today and test. Will report back
What did Sennheiser charge for the fix?
Nick Froome
beatnik
« Reply #9 on: April 16, 2019, 09:08:58 AM »
They have a 240 gbp flat rate for power problems. They replace the entire board and calibrate
pvision
« Reply #10 on: April 16, 2019, 09:58:08 AM »
There was a single KH120 on eBay recently for £325. That might be a better option as I'd end up with spare drivers as well
Nick Froome
5v333
« Reply #11 on: April 16, 2019, 03:03:31 PM »
I would check for fuse resistors that has fused.
pvision
« Reply #12 on: April 17, 2019, 02:08:37 PM »
Mosfet went in easily and blew the fuse even easier. Mosfet is now shorted. I think it's above my pay grade now
Nick Froome
beatnik
« Reply #13 on: April 17, 2019, 03:35:09 PM »
Usually the pwm driver ic blows very easily and if that is dead, putting in a new mosfet it's useless because it would short.
Man how much I hate smps. They are a ***** to repair
In this case not having schematics and labeling on the pcb makes things even harder.
But they are very nice little monitors
pvision
« Reply #14 on: April 17, 2019, 07:12:10 PM »
Which is the PWM driver? I have one more Mosfet left. Should have ordered more...
Nick Froome
Last post June 07, 2004, 04:35:28 PM
by Kev
Last post August 03, 2012, 04:40:13 PM
by mnats
Last post March 28, 2013, 10:50:04 AM
by JohnRoberts
Last post May 20, 2019, 04:57:03 PM
by beatnik
