After seeing a video on YouTube, and couple more images i am 99% sure Sphere uses regular 797audio k67 like Behringer B2 for example. Red/Yellow wire combo is another giveaway. Saddle looks like 797audio as well. Capsule graphics in the manual look exactly like 797audio capsule. So i changed the capsule in my dual output mic for 797 audio one.
My Quick Dual Output Mic:
https://groupdiy.com/index.php?topic=69193.0Sphere mic closeup:
By measuring the Sphere plugin and all the emulations against expected curves, and some of the mics i have measured in the past i came to conclusion that the original Sphere mic has high end attenuation circuit built in. It is similar to the u87, but a bit more aggressive. Their Sphere Diffuse model actually compensates for this roll off. It probably serves as a safety feature if someone tries to use 3rd party mic, and for some off axis modeling explained in the manual. The curve is easy to extract from the plugin.
Long story short, if you use dual output mic with k67 from 797audio and apply this kind of eq curve before the plugin you get the Sphere mic for cheap. The plugin is still free for download
This setup matched two vintage u87s i have measured within 0.5db in every pattern for example. Their flat model both in cardioid and omni matches my ECM8000 response, less low end on omni naturally, sm57 is very close as well. my c12 and u47 replicas are scary close.
Again, even without any emulation with a DIY stereo out mic free Sphere plugin is extremely useful tool.
