I did this in the first place. Here is the image of my sphere mic in flat mode, including correction curve i provided against calibrated Beyerdynamic measurement mic. Blue is Beyerdynamic. Naturally it has slightly less low end, due to proximity effect of Sphere which is in cardioid.
Why not measure Sphere in omni mode and compare? Well, in that case omni forming is way different than true omni capsule of Beyerdynamic, it is achieved in different manner, and it makes a lot of trouble. So it's just better to take this route. You have to trust me on this. It has to do with capsule physics. Omni capsule and k67 set in omni are nothing alike. Two membranes separated by couple of milimeters + backplate = phase issues, against one membrane with no phasing issues.
I dont see the point in using Microphone Parts capsule, 797 capsule is superior in every aspect, readily available and inexpensive. Yes it is slightly brighter, but in this case it is a good thing. Better effect of emphasis/de emphasis noise reduction. Better response above 15K.
I've taken apart somewhere around 40 various mics with this capsule, Studio Projects, Behringer, Rode, new capsules from factory, all different ages - 20 years!!! They all measured within 1db in frequency response, and couple of pF in difference.
I am sure all of this is the reason for Townsend and Slate to go with 797 audio.
