Well here's where I'm at this afternoon. Most of the time I've found myself padding the input for less harmonic distortion.
Eliminating the cathode bypass capacitors from both 6072 gain stages: The second gain stage made little difference, but eliminating the first gain stage cap resulted in -6.3 dB in THD, more linearity, and better transients, with the downside of losing 6.3 dB of gain.
The "Ribbon" switch now serves three functions:
1. Disable 48v phantom (which it does currently)
2. Bypass the input transformer secondary resistor (which it does currently, and provides 1 dB of gain)
3. Insert the cathode bypass cap to bring back the 6.3 dB of gain, plus the 1dB, for a total of 7.3dB.
This means the normal settings will provide 58.5 dB MAX gain. Selecting the "Ribbon" switch allows 65.8 dB MAX gain.
