pucho812
45mA of up to 200VDC for 13 dollars
« on: February 18, 2019, 02:29:11 PM »
interesting,  has potential to be used for DIY projects.
nothing like a DC to DC converter...
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
PRR
Re: 45mA of up to 200VDC for 13 dollars
« Reply #1 on: February 18, 2019, 02:39:18 PM »
Does this exist? Or only in your dreams? Link?
pucho812
« Reply #2 on: February 18, 2019, 03:20:25 PM »
I thought I linked it.
oh well here you go
http://www.tayloredge.com/storefront/SmartNixie/PSU/index.html
« Reply #3 on: February 18, 2019, 06:40:51 PM »
No mention of output ripple in the spec but I guess that is not too relevant for Nixie tubes.
« Reply #4 on: February 18, 2019, 06:59:07 PM »
I just noticed ha also modifies a commercial off line switcher to provide 180V at up to 230mA. Maybe he could do a version that does 250V at 160mA?
pucho812
« Reply #5 on: February 18, 2019, 07:04:52 PM »
yes no mention of ripple.  but interesting none the less.  I had an idea for using Nixie tubes as part of a stepped volume control, each step as you increase in volume is another number in the nixie.
Matador
« Reply #6 on: February 19, 2019, 01:28:34 PM »
I've had a lot of success with Nixie PSU's, especially the SMPS designs.  Mostly because the ripple frequency is (typically) quite high:  in one design I adapted, the minimum ripple frequency has approximately 53kHz, and the maximum was near 250kHz.  This means RC and LC filtering is substantially more effective (like 70-80dB) as compared to filtering typical 100Hz/120Hz ripple.
iampoor1
« Reply #7 on: February 21, 2019, 10:30:11 AM »
Which designs did you try?
I have been meaning to try this one. The BOM cost is pretty high tho. https://desmith.net/NMdS/Electronics/NixiePSU.html
If noise and ripple is an issue, easy enough to follow it up with a linear regulator. :)
volker
« Reply #8 on: February 21, 2019, 11:06:21 AM »
This one is a bit cheaper to build. I have a couple of pcbs left if somebody is interested.
Last post January 03, 2011, 06:16:39 PM
by JohnRoberts
Last post September 12, 2011, 01:37:12 PM
by 0dbfs
