45mA of up to 200VDC for 13 dollars
I just noticed ha also modifies a commercial off line switcher to provide 180V at up to 230mA. Maybe he could do a version that does 250V at 160mA?
yes no mention of ripple.  but interesting none the less.  I had an idea for using Nixie tubes as part of a stepped volume control, each step as you increase in volume is another number in the nixie.
I've had a lot of success with Nixie PSU's, especially the SMPS designs.  Mostly because the ripple frequency is (typically) quite high:  in one design I adapted, the minimum ripple frequency has approximately 53kHz, and the maximum was near 250kHz.  This means RC and LC filtering is substantially more effective (like 70-80dB) as compared to filtering typical 100Hz/120Hz ripple.
Which designs did you try?
I have been meaning to try this one. The BOM cost is pretty high tho. https://desmith.net/NMdS/Electronics/NixiePSU.html
If noise and ripple is an issue, easy enough to follow it up with a linear regulator. :)
This one is a bit cheaper to build. I have a couple of pcbs left if somebody is interested.
