RCA 900491-502?
burdoto
St Paul, MN
I have what I think is a RCA transformer with the number 900481-502. It has four leads. I have been scouring the old literature to possibly run the part number somewhere but I can't not find it. Does anyone know anything about this baby?
491 is a power transformer with more than 4 leads.  No idea what 481 is.
DC resistances?
That would probably be a filament transformer of some sort.  110-115VAC on the higher side.
On a slightly different subject, I bought some Collins transformers that I did not realize came from an aircraft servo amplifier.  One of the transformers  is a 400hz power transformer(115v to 6.3v), the other transformer is an audio input transformer which appears to be 1k:100k.  A possibly dubious spec sheet I found for it states the turns ratio is 1:20.
Firstly, does anyone know what a servo amplifier is? Possibly this a servo for controlling an aileron  perhaps...etc.
Secondly, does a servo amplifier truly use an audio transformer, and if so, can I use it for something?
