pucho812
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
moamps
Re: DIY test equipment
« Reply #1 on: February 20, 2019, 04:29:29 AM »
Interesting design, but IMHO the lorlin type rotary switches will not last long, especially in HT and heaters positions.
The initial heater current for some output tubes is way over the lorlins current rating.
pucho812
« Reply #2 on: February 20, 2019, 01:43:13 PM »
true but still impressive one was built.  ;)
« Reply #3 on: February 21, 2019, 02:58:21 AM »
What surprises me is the guy can afford an A0 plotter yet he etched his own PCBs.
iampoor1
« Reply #4 on: February 21, 2019, 10:32:56 AM »
I think for the "craftsman" type like this, going PCBs from a fab would be heresy.  ;D
« Reply #5 on: February 21, 2019, 02:34:42 PM »
But not drawing his schematics by hand isn't??
Rob Flinn
« Reply #6 on: February 24, 2019, 04:36:10 AM »
That's probably why he can afford an A0 plotter  ....
regards Rob
joaquins
« Reply #7 on: February 24, 2019, 11:11:09 PM »
I etch PCBs for projects where it probably many wouldn't... like industrial applications where PCB costs wouldn't be a problem, but for me delay times are usually way too long, and I can be mounting components on the etched PCB an hour after design is ready.
I'd run 3 prototypes in a night for small things when time is tight, good luck doing that with production PCBs, and for one offs, friendly PCBs like that project, no brainer.
JS
If I don't know how it works, I prefer don't turn it on.
benb
« Reply #8 on: February 24, 2019, 11:21:39 PM »
I see all the switches along the bottom for tube pinout configuration - was this based on an existing tube tester? That would make it easy to use the printed "database" of the original and all the tube types it gives.
If I were me I'd absolutely use a microcontroller and a bunch of relays and/or transistors and mosfets to do the same thing. You could "scroll through" a small display that shows each tube type, scrolling through by sorted type number, or by the most common types (12ax7) first. The whole database would be in program memory.
Last post November 27, 2004, 06:55:17 AM
by Ribbledox
Last post June 23, 2007, 03:05:30 PM
by tomelectro
Last post February 06, 2008, 09:40:51 PM
by JohnRoberts
Last post July 10, 2012, 01:55:07 AM
by leadbreath
