Silly question about P&G 8120
Rob Flinn
Between Sussex, UK & Aude, France.
Just hooking up some of these faders & I want to check that I'm getting the connections right.
See attached data sheet.  When you look at the wiring diagram for the 8120 the ends of the fader are labelled 0dB & infinity dB.
Which one of these should be the top of the fader i.e where the signal is fed in ?    I'm think that infinity dB should be where the signal is fed in  & 0dB should be the 0v connection.  But then a lot of faders are labelled - infinity when the signal is turned down.  Just checking because i don't want to wire up a whole desks worth of them wrong .....
  • PGF8000_brochure_sept11(EN).pdf
Attenuation 0dB to infinite (as shown in the panel garduation/slots section on the data sheet), so feed to 0V...
Also "pin 2 (infinty)&3 should joined to obtain cutoff"...
I DON´T KNOW IT but everything else would be highly misleading!
Try the opposite...  0dB is unity gain or the top of the fader. Minus infinity is full attenuation or the bottom.
You can wire up just one and check...
That makes sense comparing to the graduation for the faceplate, but really it's -infintity no infinity, so the sheet is a bit misleading....
Not really. The designations refer to attenuation.
So 0dB indicates no attenuation ( unity 'gain' ie 0dB)
'infinity' indicates infinite attenuation
Of course mixing desks are often configured to have, say, 10dB gain at the top of the fader but that is realised electronically (obvs).
The 'infinite'  end of the fader is still infinite attenuation (ideally).
For transparency : ex- P&G employee
btw - and apologies if pointing out the obvious - but the 8000 series have carbon loaded plastic bodies (assuming they are same as when I was there). To get proper screening you must 'earth' (ground) them at the insert as indicated in the datasheet figure.
I recall we had complaints where a customer had neglected this (maybe used nylon screws - it's a long time ago now !)
I think the confusion came into because I had to design some fader plates for them.  I was looking at some incompatible fader plates I had for some inspiration & all the figures on the plates had a "-" before the figure.  i.e -5, -10 etc  Whereas the P&G data sheet panel graduation chart just has the numerals.
