The distortion and bulb does give quite a crack to even a thin synthetic snare ,
The bulb effectively prevents the drive transducer of the tank from overloading , a good thing as it doesnt sound much good when it does . You can dial in as much distortion as you like to add an extra dimension or sparkle to the sound .
Rod Elliots site has some info on a simple lamp driven tank circuit here ,
http://sound.whsites.net/articles/reverb.htm
Im not sure why Rob didnt put the bulb in series with the tank ,other than that it does bear a striking resemblance to the Grampian drive setup .
Ive have a few tanks set up lately for test purposes , So from a small audio mixer I connected the main outputs to a pair of Accutronics 250 ohm input 2250 ohms output tanks , I had initially tried mic in as return but the low loading of the output transducer didnt allow the spring to sing out properly . Ive now used a pair of active DI boxes to present a couple of meg ohms to the output transducers of the tanks , tons more level and sparkle although the basic gain of the Di box at 20 db is still a little on the low side . The springs being run off the main outputs and returned on a channel theres always some feedback but the loop lenghtens the reverb time and smoothes the edges in the decays ,theres a delay of about 30-50 ms across the spring ,a small proportion of the output signal fed back adds a thickening the effect .
At the moment I just have the drive transducers connected unballanced to my mixer outputs but if I was to untie one side of the input transducer from ground and provide balanced connection could I expect an increase in drive levels ?
I have some 6.3 volt lamps , the usual kind you find as backlighting or indicators on old gear , they work well as limiter on the speaker line of smaller powered amps ,but I never tried them on line level or op amp type drive impedences .
Hi Das ,
glad you enjoyed the sound , more like a gunshot in a cathederal than a snare ,
Often little stand alone record players from the mid to late 60's have Germainium amps built in , three transistors and a driver transformer , exactly whats in the Grampian . I have a small board from one of these in the shed with mullard GET transistors , I might dig that out for fun .
Really once you have yourself a tank to experiment with you can easily make some kind of a noise . The average hifi reverb ad-on in the video clip sounded bad , the Grampian was the only one of the bunch that provided overdrive and compression on the springs inputs . I think many of the guitarists who used the grampian also used it as a gain booster/distortion on their direct signal as well as reverb .
Even though in the modular synth community spring reverbs are very popular ,very few if any of the modern offerings do much sonically for me , some intentionally overload the input transducer and call that a sound , most have feedback control which is nice , but they all seem to have completely missed unleashing the real animal in the tank , by making a decent spring driver stage with loads of power/ nice overload and placing a lamp and attenuator on the line so you can prevent satuaration of the coil/core . or add compression .
A little custom pcb/eurorack front panel could easily give Doepfers A-199 a good sonic punch in the face at 100 bucks , Discrete transistor drive off an op amp like in Rods setup , the lamp ,the attenuator ,a cv controllable filter on the return .A reverb kit for the modular and home constructor would sit up very nicely in the thousands of other synth gadgets .
I just had a chance to try a brand new Belton short tank , two spring model , compared to the old Accutronics it has a good bit more output, coil impedances more or less the same , the Belton core and coil assemblies look great everythings neat and tight and the coil wires attach in direct to the winding ,not a plastic plug like later Accu's. The small tank Belton is as good as or better sounding than any of the long tank accutronics units I have, ,definately no quality control problems , and the core/coil is screwed together not rivited like the Accu's ,so makes it easier to rewind if you need to for a different impedance or because the coil is open.
