Re: Steel for enclosures
« Reply #20 on: March 16, 2019, 06:16:53 AM »
I've always liked the look of the yellow zinc plating. But other than appearance, would stainless steel be a viable option since it has corrosion resistance?
Unfortunately stainless has no magnetic shielding properties.
john12ax7
« Reply #21 on: March 16, 2019, 09:38:30 PM »
That makes sense regarding stainless.  I did a little more research on it,  it seems some stainless is ferromagnetic,  but the 300 series is not,  which is unfortunately the one commonly used in sheet metal fabrication.
shabtek
« Reply #22 on: March 16, 2019, 10:07:19 PM »
I gave close inspection to my galvanneal chassis that have been in damp storage for a few years and there is a fine line of iron oxide on one side of the sheared edge
"really fine players do not use stomp boxes or master volume, they match the amp to the room and turn it up to 11.  Stevie Ray, BB King, Albert King, Duane Allman, Dicky Betts, Louis Armstrong"
   -CJ
Brian Roth
« Reply #23 on: March 17, 2019, 02:12:52 AM »
As I recall, you shear/punch/bend the sheet metal and THEN plate it to avoid bare steel edges which will rust.
Bri
Brian Roth Technical Services
Salina Kansas, home of the best vinyl on the planet!
http://www.BrianRoth.com
recordingservicesandsupply.com/
www.qualityrecordpressings.com/
store.acousticsounds.com
abbey road d enfer
« Reply #24 on: March 17, 2019, 05:19:14 AM »
Look for cadmium-plated steel. It was the standard surface treatment decades ago.
Check if permitted in your country. I'm not sure it is permitted anymore in France.
Now advantageously replaced with vinyl-covered zinc-protected steel.
https://www.finishing.com/355/28.shtml
« Last Edit: March 17, 2019, 05:38:13 AM by abbey road d enfer »
Brian Roth
« Reply #25 on: March 17, 2019, 09:58:09 PM »
Thinking back to Neve modules....I used to maintain an 8068 desk for a friend/client, and the steel parts were plated with perhaps Chrome.  Not mirror-finish like the bumpers on a 1950's Cadillac, but pretty shiny.
Bri
abbey road d enfer
« Reply #26 on: March 18, 2019, 02:28:29 AM »
Bri
That was a long time ago. Today, the metalworkers get the sheet metal zinc-plated and vinyl-coated. Punching and shearing leaves parts unprotected. In a standard studio environment is is not a serious issue. Planned obsolescence makes sure the unit goes duff before it's rusted to the bone.
Now it's a different story if you install the gear in a boat.
[silent:arts]
« Reply #27 on: March 18, 2019, 03:15:04 AM »
My (german) metalworker told me the same thing for my L-Brackets.
Now I have customers in Singapore not liking the rusty look nobody in Europe ever reported ...
abbey road d enfer
« Reply #28 on: March 18, 2019, 03:53:56 AM »
For internal metal parts, I've always favoured stainless steel. Generally, these are small parts so the cost of material is irrelevant.
shabtek
« Reply #29 on: March 25, 2019, 02:19:59 PM »
The zinc in galvaneal surface tratment reacts with the iron oxide at the raw machined edges minimizing corrosion.
I wonder if a rust neutralizing treatment/wash would adversely affect this action...? Assuming no additional protective coating will be applied.
   -CJ
« Reply #30 on: March 25, 2019, 06:41:22 PM »
I received the Zintec parts the other day. I must say I am rather disappointed. A rather dull uneven grey surface with a lot of marks on it. Not up to the usual standard of this supplier. I think I need to get plain mild steel and send it out for finishing.
abbey road d enfer
« Reply #31 on: March 26, 2019, 03:24:30 AM »
Seems to indicate it was not vinyl-covered.
« Reply #32 on: March 26, 2019, 03:28:51 AM »
I think you are right. I have had aluminium and stainless from the same place and both had the vinyl pull off covering on them but the cold rolled mild steel never did.
abbey road d enfer
« Reply #33 on: March 26, 2019, 03:42:14 AM »
I guess you have to specifically ask for it. I've never seen it on unprotected steel. Only on zintech. I guess metalworkers take for granted that unprotected steel will necessarily be treated later.
Marik
« Reply #34 on: March 27, 2019, 01:08:02 AM »
The 4 hundred series has. Check 416, 420, 430 SS--whatever is available in your area...
Best, M
Samar Audio & Microphone Design
www.samaraudiodesign.com
The Art of Ribbon Microphones
« Reply #35 on: March 27, 2019, 04:48:21 AM »
Best, M
Thanks, I will check those out.
john12ax7
« Reply #36 on: March 27, 2019, 03:28:13 PM »
Best, M
Are those common in sheet metal enclosures and easily bendable?
« Reply #37 on: March 27, 2019, 08:22:18 PM »
Fortunately for my purposes it is not necessary to bend it.
JMFahey
« Reply #38 on: March 28, 2019, 04:43:55 AM »
Zintec is the **cheapest** usable (sort of) metal finish.
Dull gray and surface coat is easy to scratch, will *definitely*  show folding machine jaws, etc.
Chep because metalworker buys the precoated full sheet , think 600mm x 2000 mm, 1000mm x 2000mm in Europe (or here in Argentina), 3 ft by 4 or 6 or 10 ft in US/Canada, etc.
They just cut/punch/bend it and send part to be used as is, no further tretment.
Rust protection is "reasonable", just don´t let in the rain, in a condensing humidity place or even less let Coke or beer spill on it.
All machined edges (cut/ounched, etc.) are exposed and will rust eventually.
As said above, betting equipment will be junked before that.
Typical of Marshall amplifier chassis (think cheap Valvestate, not expensive MKII/Plexi reissues which deserve proper zinc plating after machining), lots of Laney stuff, generic computer SMPS or even internal chassis elements, etc.
NOT meant to be "outside" where it can be seen and no protective transparent or blue peelable vinyl sheet which are used only to protect *polished/shiny/smooth blasted*  Aluminum or Stainles Steel surfaces.
Acrylic or "high impact" plastic sheets also come with a protective film.
So if you want a good durable finish machine your sheet metal and then plate or paint it.
Cold rolled steel can be passivated, it´s called Phosphatization.
Surface n
becomes relatively stable, but dull and pearl gray in colour.
In general it´s not meant to be used on its own but to passivate steel , dissolve preexisting oxide spots and provide an *excellent*  base for painting.
When I am out of speakers, a new batch takes about 1 Month from raw steel to packaged speaker, so to satisfy anxious customers I pull a dozen frames, phosphatize and spray paint them , then assemble and deliver.
The others get the usual bluish Zinc plating.
Customers are happy.
Design - Make - Service Audio Equipment since 1969.
« Reply #39 on: March 28, 2019, 07:02:30 AM »
Many thanks for the insight. I tried some Zintec and I am not happy with the appearance. I think I will use cold rolled mild steel, drill the holes I need and then have it treated - could be passivation, plating or painting - I think I prefer plating. Just need to find somewhere local to d o it.
Last post September 13, 2004, 02:31:42 PM
by MikoKensington
Last post November 08, 2004, 01:36:27 AM
by PRR
Last post April 07, 2005, 03:46:31 PM
by Repairman
Last post May 13, 2009, 01:26:40 PM
by AMaziad
