CJ
Egnater Rebel 20 Guitar Amp
« on: March 21, 2019, 08:02:41 PM »
just a blown B+ fuse, those small sized fuses do not seem to stand up as well as the AG3,
bumped it from 500 ma to 1 A,  as full blast current was up there,
Quad of power tubes, 2 ea 6V6GT and 2 ea EL84 with a blend knob to use either or which is a novel feature,
but we get to have a lookise inside !
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
CJ
Re: Egnater Rebel 20 Guitar Amp
« Reply #1 on: March 21, 2019, 08:03:58 PM »
OPT done on 100 EI sq stk,
CJ
« Reply #2 on: March 21, 2019, 08:05:40 PM »
CJ
« Reply #3 on: March 21, 2019, 08:06:55 PM »
power tube mix circuit done on the pot with daughter board,
CJ
« Reply #4 on: March 21, 2019, 08:08:25 PM »
OPT sq wave response unloaded,
CJ
« Reply #5 on: March 21, 2019, 08:13:02 PM »
had to fill in ref designators only to find out later that there is another , schematic with the values but no big,
preamp with blue = dc red = ac
marshall follower drives stack,
dual gain pot on preamp,
CJ
« Reply #6 on: March 21, 2019, 08:16:27 PM »
PI and mix circuit
i heard no big diff between EL84 vs 6V6, maybe some Amperex 6BQ5's would add a difference,
amp gets slightly louder with the mix knob set for both tubes,
this amp also has a wattage adj knob which  starves the PI via cathode,
CJ
« Reply #7 on: March 21, 2019, 08:22:26 PM »
and the power amp with OPT info,   about 9K P-P into voice coil,
might be a bit high for both tubes on parallel,
nice sounding amp!   could be simplified as a project by leaving off the mix circuit,
CJ
« Reply #8 on: March 21, 2019, 08:35:27 PM »
here is a pdf with values and no voltage clutter,
Last post February 02, 2009, 10:51:35 PM
by abby normal
Last post January 11, 2010, 08:51:43 AM
by bitman
Last post December 16, 2010, 03:40:32 AM
by abbey road d enfer
Last post July 24, 2013, 04:51:54 PM
by Rochey
