pucho812
trident TSM eq edge connector
« on: April 02, 2019, 01:24:57 PM »
I picked up a tsm eq and although it's racked in a chassis, I need an edge card for it.
Does anyone have a part number for that?
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
Re: trident TSM eq edge connector
« Reply #1 on: April 03, 2019, 11:03:46 AM »
Not 100 percent certain about the TSM , but the A Range used McMurdo Red Range connectors. I believe there is an another manufacturers equivalent as well but I cannot remember which one.
I hope that is of some help.
Jeff
pucho812
« Reply #2 on: April 03, 2019, 01:14:42 PM »
I service 2 X a-range consoles here in L.A. I know the mcmurdo.  The TSM eq section is a 24 pin edge connector. I assume a 24 pin(48 total as it is 2 rows) edac edge connector will do.  But I wanted to confirm the spacing of the pins so I can get the correct one.
« Last Edit: April 03, 2019, 03:42:45 PM by pucho812 »
QUEEF BAG
« Reply #3 on: April 04, 2019, 01:31:00 PM »
dunno about the connector, but would sure love to find replacements for the faders...
pucho812
« Reply #4 on: April 04, 2019, 02:00:12 PM »
I much rather just have pots with a center detent. perhaps that can turn into a DIY project down the road. the tsm eq with pots instead of faders.
Brian Roth
« Reply #5 on: April 04, 2019, 08:59:40 PM »
When in doubt, breakout the calipers/rulers.  Common center spacings were 0.156", 0.150", 0.125" and 0.100".
I'll typically measure the total spacing for 10 contacts, then divide by 10 to get the individual spacings.
Bri
Brian Roth Technical Services
Salina Kansas, home of the best vinyl on the planet!
http://www.BrianRoth.com
recordingservicesandsupply.com/
www.qualityrecordpressings.com/
store.acousticsounds.com
pucho812
« Reply #6 on: April 04, 2019, 10:47:09 PM »
Bri
I did, but I’d worth asking here as I am sure one of us took this trip before
mjrippe
« Reply #7 on: April 05, 2019, 11:19:21 AM »
Maybe post the results for the next person who takes this trip?  There was someone asking about Fleximix connector spacing here recently and I bet it is the same.
pucho812
« Reply #8 on: April 05, 2019, 11:24:59 AM »
I intend to when my edge connector arrives.
pucho812
« Reply #9 on: April 18, 2019, 10:26:04 PM »
ok I got  edac part number 345-072-500-202
it's 2 rows of 36 pins.  it fits the edge cut out on the eq PCB and pins line up to work. it may not be the exact same as in a desk frame, but the manual  I have does not list them or discuss that.  this will be in a rack mount so no worries there...  8)
Last post June 20, 2013, 05:24:55 PM
by kpearsall
Last post April 16, 2018, 06:37:21 PM
by JMarcovis
Last post June 16, 2018, 12:32:51 PM
by pucho812
Last post March 20, 2019, 03:08:49 PM
by bobober
